refra_151287's avatar
Mar 06, 2016
ASM Requirements
Hi all,
I've the following inquires:
  • how to configure F5 to send alerts every time signature update occurs.
  • Is the default Search engines configured at the ASM is enough or i have to add the other engines.
  • When we use proactive bot defense in DOS profile (v11.6), as I guess it's the same as webscraping?
  • Expired timestamp issue, we always have this issue at one application for the ASM cookie, and of course it disappears when I delete the browser cookies, do you have any idea why this violation happens, and how to fix it?
    sign up for the security mailing list on support.f5.com.
    This depends on your needs. * When we use proactive bot defense in DOS profile (v11.6), as I guess it's the same as webscraping? Related, but not exactly the same. Proactive Bot Defense stops the attacks before they occur. Webscraping stops attacks that are already underway. * Expired timestamp issue, we always have this issue at one application for the ASM cookie, and of course it disappears when I delete the browser cookies, do you have any idea why this violation happens, and how to fix it? You will need to give us more information if you want help with this. I would also suggest that you consider opening a case with support to have them help with this.
