ASM - Problems with curl monitoring / crawler - please enable JS
recently I implemented an ASM policy with the Sharepoint template in transparent mode. No DoS profile.
Unfortunately I ran into an issue with - I assume - the browser check.
Our external Nagios-Monitoring does a curl request and looks for a specific keyword in the response to check the health of the external service.
Currently the response doesn't contain a page, but following output:
Please enable JavaScript to view the page content.
Your support ID is: 2863805088290756184.
I can't figure out why this is happening. I can't even find anything with this support ID, neither in App Events, nor in DoS events.
In the learning and blocking settings the "Web scraping detected" signature is deactivated.
If I add the source IP to a whitelist, it works for my test client all the time. But adding the Nagios IP doesn't work (only random).
I'm not sure what more I could check/change here - any ideas?
