zakaria12's avatar
zakaria12
Oct 24, 2022
asm liveupdate not working
Hello,
We have a problem with liveupdate not automatically bringing updates.
When we click on check for updates its stuck on Checking for updates.
Please is there any solution for this issue?
Thank you,
  • Hope Live update ports are open properly. if it stuck just go back to other screen and re-try.
    • if that doesnt help, what does the logs show at the moment?
      /var/log/ts/asm_config_server.log
      /var/log/tomcat/liveupdate.log
