ASM Guided configuration is missing
hrdina28
Hello guys,
please I am having weird issue, I cant see Guided configuration at all. I am running 15.1 version with lab license for LTM and ASM. Dont you know, what might be an issue?
Thank you
Best regards
1 ACCEPTED SOLUTION
Erik_Novak
F5 Employee
F5 Employee
Guided Configuration requires the Advanced WAF (AWF) license.
5 REPLIES 5
Samir
Nacreous
Nacreous
We believe you need to upgrade Guided Configuration as well to new version. Please check the below points.
You can upgrade use case packs to get the latest guided configurations.
  1. On the Main tab, click Access > Guided Configuration or Security > Guided Configuration.
  2. On the top right of the page, click Upgrade Guided Configuration.
  3. Click Choose File and select the Use Case pack to upgrade.
  4. Click Upload and Install.
# ls -al /var/config/rest/iapps/ total 12 drwxr-xr-x. 3 root root 4096 Jan 21 08:53 . drwxr-xr-x. 13 root root 4096 Jan 19 12:34 .. drwxr-xr-x. 2 root root 4096 Jan 19 09:22 RPMS
After that
From CLI try issuing the following command then attempt to access guided config again:
  • bigstart restart restjavad restnoded
hrdina28
Hello Samir,
thank you for the reply. Well I cant, because i fail on first step, Guided configuration is not in menu at all. I played a little bit with Strongbox licenses and it seems that Guided config appeared with LAB-VE license. When I used ASM or WAF or LTM+WAF, then nothing. I think my problem is related to the license. Is that possible?
Thank you
Best regards
Samir
Nacreous
Nacreous
Not sure about LAB-VE License feature did you restart the demon service `restjavad restnoded`.
Lets see if issue solved?
hrdina28
I did, nothing 😕 . Only license change helped.
Erik_Novak
F5 Employee
F5 Employee
