15-May-2021 23:27
I'm facing below error when I'm trying to view event logs :
DBD::mysql::st execute failed: Out of resources when opening file './PRX/REQUEST_LOG
what is mean ?
Solved! Go to Solution.
16-May-2021 00:29
Hi THE BLUE,
maybe you are affected by the known issue with Bug ID 947341. Check if you are running one of the known affected TMOS versions. There is a Support Solution for this issue:
KR
Daniel
16-May-2021 00:29
Hi THE BLUE,
KR
Daniel
16-May-2021 21:50
many thanks for your help , I did the necessary as above.
