Technical Forum
AS3 pool members using a list
mihaic
MVP
MVP
I have started to play with AS3. I've tried some examples and they work fine.
But I have counter a problem. Maybe it is not possible.
I am using Terraform and AS3 data template to configure a virtual server.
data template_file "init" {
  template = file("example.tpl")
  vars = {
    TENANT = var.TENANT
    VIP = var.VIP
    POOL = var.POOL
    LB_MODE = var.LB_MODE
    MONITOR = var.MONITOR
    MEMBERS = jsonencode(var.MEMBERS)
resource "bigip_as3"  "as3-deploy-tenant" {
     as3_json = data.template_file.init.rendered
MEMBERS is a list :
variable "MEMBERS" {
  type    = list(string)
  default = []
MEMBERS = ["1.1.1.1","9.9.9.9"]
 I am using jsonencode() function as it seems this is used for lists in Terraform.
It seemed it did not work. I get this:
Planning failed. Terraform encountered an error while generating this plan.
│ Error: "as3_json" contains an invalid JSON: invalid character '1' after array element
│ with bigip_as3.as3-deploy-tenant,
│ on main.tf line 25, in resource "bigip_as3" "as3-deploy-tenant":
│ 25: resource "bigip_as3" "as3-deploy-tenant" {
It works if MEMBERS is just a string variable. Or if I choose just the first element of the list for example without the jsonencode function.
But I was wondering if I could use a list because I ma trying to do this in my template file:
"${POOL}": {
"class": "Pool",
"loadBalancingMode":"${LB_MODE}",
"monitors": [
"${MONITOR}"
"members": [
"servicePort": 80,
"serverAddresses": [
"${MEMBERS}"
Thanks in advance for any hint you might have.
1 ACCEPTED SOLUTION
Try removing the square brackets and quotes around the ${MEMBERS} variable in the JSON. I spotted this example from one of @Sebastian_Maniak 's guides:
in the module:
    MY_POOLMEMBERS = jsonencode(var.pool_members)
in the json:
          "members": [{
            "servicePort": 80,
            "shareNodes": true,
            "serverAddresses": ${MY_POOLMEMBERS}
4 REPLIES 4
Leslie_Hubertus
Community Manager
Community Manager
Hi @mihaic - @Sebastian_Maniak may be able to help here. 🙂
in the module:
in the json:
          "members": [{
            "servicePort": 80,
            "shareNodes": true,
thanks!!!!!!
It worked.
I don't know how I haven't tried this option before.
