26-Feb-2020
15:41
- last edited on
22-Nov-2022
15:14
by
JimmyPackets
In all the example declarations I've seen so far, it lists the virtual server name as serviceMain and if I deviate from that by giving it my own virtual server name like testme123.example.com-80 it complains about not using serviceMain. How can we supply a different VS name on an AS3 declaration?
Here is the error message. I used a Python get request to send the declaration. I'm using a Simple HTTP AS3 declaration.
('Status Code:', 422, '\n', u'{"code":422,"errors":["/Sample_01/A1: should have required property \'serviceMain\'"],"declarationFullId":"","message":"declaration is invalid"}')
Solved! Go to Solution.
27-Feb-2020 10:19
I believe this has to do with the template type you are using.
Try to change the template from http to generic and then change the serviceMain to testme123.example.com-80.
When using the 'http' template I can get the same error:
"Sample_01": {
"class": "Tenant",
"testme123.example.com-80": {
"class": "Application",
"template": "http", <<<<<<<< Change to generic
"serviceMain": {
"class": "Service_HTTP",
"virtualAddresses": [
"10.0.1.11"
Altered the template type to generic and it deployed the virtual server with the matching name:
"Sample_01": {
"class": "Tenant",
"template": "generic",
"10.0.1.11"
27-Feb-2020 10:19
"Sample_01": {
"class": "Tenant",
"serviceMain": {
"10.0.1.11"
"Sample_01": {
"class": "Tenant",
"10.0.1.11"
27-Feb-2020 11:23
Thank you very much! I tried the small change above and it works. There wasn't a lot of information on the documentation about doing it this way. I figured it's absolute nuts to see all your virtual servers named serviceMain. Do you have a sample template of the full declaration for a generic virtual server. I figure we would want to change some of the profiles like TCP protocol, etc.
