Technical Forum
Custom Alert Banner
are Hot Fixes still available for installation ?
Edouard
MVP
MVP
When I upgraded before I had the option to download the image and its HF. Now I am not able to see its HF.
Please let me know if HF's are discontinued.
Thanks,
Edouard.
1 ACCEPTED SOLUTION
Yes it is included in the image. F5 have changed how they manage hotfixes now. First they are not called hotfixes anymore. Instead it is referred as ‘Point Releases’, which is forth number in the version number. So in 14.1.2.6, number 6 is referred to point release/hotfix. So you no longer need to install a primary ISO and a separate Hot-Fix ISO. All you need is to have image of target version thats it.
Mayur
3 REPLIES 3
Samir
MVP
MVP
Which software version of F5 hotfix you are searching? ​
Edouard
MVP
MVP
14.1.2.6. Apparently the HF is included in the image now ?.
Mayur
