Technical Forum
APM Webtop didn't appear in the Advanced resource assignment agent in trial VM V17.1.0
Ireda
Cirrus
Cirrus
APM Webtop has been created successfully, but it didn't appear in the Advanced resource assignment agent. trial VM V17.1.0
Kindly check the attached images.
1 ACCEPTED SOLUTION
Hi Ireda,
Is Webtop's customization type different from access policy?
If one is modern and the other is standard, you cannot add the webtop in access policy. Webtop object does not appear in the list.
2 REPLIES 2
Hi Ireda,
Ireda
Cirrus
Cirrus
Thanks, you are right.
Solved
