Technical Forum
APM variable assign to trim ad group DN
Nolan_Jensen
I have created a variable assign in access policy based on some code I found on this site. This code allowed me to remove the AD distinguished name and just capture the name of the group in a variable.
That said we recently had a requirement to add a some leading characters to the group name that I also want to remove but not sure how to do both.
My current custom variable code this this
set mem_fields [split [mcget {session.ad.last.attr.memberOf}] "|"]; foreach mem $mem_fields { if { $mem contains "Test" } { set found $mem } }; set grp_fields [split $found "=,"]; return [lindex $grp_fields 1];
That takes this group DN CN=DIV-Test-123456-read-only,OU=Groups,OU=One,OU=Two,OU=Three,DC=Organization,DC=com
and converts to DIV-Test-123456-read-only
What I would like to do now is modify the code to return this instead (remove the DIV from the group name as well as remove all DN related stuff)
Thank you in advance for you time!
1 ACCEPTED SOLUTION
Nolan_Jensen
I figured this out, so updating incase someone else runs across this.
Since the group name I wanted to send had a bunch of - that made this more complex. So I changed the group name from
to
DIV_Test-123456-read-only (to an underscore instead of a - between DIV and Test)
This allowed me to then use this modified code:
I then added a _ to the Split $found section and change the $grp_fields from 1 to 2
set mem_fields [split [mcget {session.ad.last.attr.memberOf}] "|"]; foreach mem $mem_fields { if { $mem contains "Test" } { set found $mem } }; set grp_fields [split $found "=_,"]; return [lindex $grp_fields 2];
1 REPLY 1
Nolan_Jensen
to
