Technical Forum
APM Sharepoint
TimC28
We are attempting to migrate a Sharepoint Site that has 2 virtual servers from a Netscaler to F5. There are 3 separate user authentication domains. When I test directly to the Sharepoint site, I can successfully log in w/o domain notation.
Is it possible to setup a F5 Logon Page that does not authenticate the user but only collects the username and password and passes to it the Sharepoint server?
1 REPLY 1
SanjayP
MVP
MVP
do you have APM module installed? If your users are using domain joined machine and they use domain credentials to logon you can take a look at the option of Kerberos SSO.
https://support.f5.com/csp/article/K43063049
