08-Jun-2017
06:12
- last edited on
15-Dec-2022
08:53
by
JRahm
Is anybody aware of a master code list for when sessions are deleted (i.e. user logs out or times out, etc)? For example, I see various codes that appear like this:
Jun 8 08:47:00 x.x.x.x /Common/main:Common:abcdefgh: Session deleted (unknown_error; code - 24577).
I tried searching for something on F5's site... but I'm striking out.
Thanks-
01-Aug-2017 12:33
You may have a look at the following file in your bigip device :
/var/sam
This file contains mapping with error codes when denying a session. I'm not sure it is 100% related to your issue.
Good luck
Yann
02-Aug-2017 04:37
Hmmm, interesting. Good info - thank you, but the numbers only go up to 8002 in that file, whereas the errors I am referring to above go far beyond that number regularly - so I'm not sure if it's 100% related (as you indicated).
02-Aug-2017 05:13
I think the best is to open a support case with F5.
