Benjamin_8557's avatar
Benjamin_8557
Mar 15, 2019
[APM] OIDC Session Management
Hi!
I'm trying to configure BIGIP as OpenID Connect Provider with APM v14.1.
Authentication works well but I wonder if v14.1 is implementing OIDC Session Management too.
I cannot find any end_session_endpoint or check_session_iframe endpoints in my .well-known/openid-configuration json file.
Maybe there is some feature to activate but I can't find it. Or maybe is it planned for v15?
If not, it's not possible to provide SSO/SLO, am I right?
Then , I wonder if it's possible to provide Dynamic Client Registration ? I can't find any register endpoint as well.
Thank you for your help!
regards
Benjamin
  • I have the same problem with APM v17.1 I cannot find any end_session_endpoint in my .well-known/openid-configuration json file. Please advise how to implement RP-Initiated Logout.
    Best regards,
    Tom
