APM logon checkbox checked by default
Hello All,
I'm new to APM and have a dumb question. How can I make a checkbox item on a logon page checked by default?
Why simply not remove the checkbox and have just a username and password input as having a checbox auto being checked by default removes its purpose?
- Shorton88
The checkbox is required if I understand correctly for change_password on logon. I am trying to make a password change portal and only want to allow logons that are change password attempts.
- PSFletchTheTek
Cumulonimbus
Some sort of question to what Shorton88 just asked.
What are you trying to achieve?
What's the tickbox assigned to, and what are you trying to achieve with it?- Shorton88
