TimRiker's avatar
TimRiker
Dec 13, 2022
APM LDAP by path
I'm trying to figure out a means to allow different LDAP query limits for different paths on the same server.
I can add the various ldap queries to a string datagroup indexed by hostname/path (as the virtual server will hopefully handle other servernames too) and insert them into a session.ldapsearch through use of a table/subtable. I tried just variables, but the iRule event ACCESS_POLICY_AGENT_EVENT does not appear to "see" variables created in other sections of the same iRule. This is further complicated when using http2 as request events can happen in different iRule context.
The issue is if I create an "LDAP Query" instance in the APM flow and use something like:
(cn=%{session.oauth.client.last.id_token.cn})
This works fine, but something like:
(&(cn=%{session.oauth.client.last.id_token.cn})(%{session.ldapsearch}))
Does NOT work as session.ldapsearch is RFC-4515 escaped as if it were a single entity instead of a formatted search.
How do people add different LDAP checks for differnt paths on a server using APM?
If this were just a single group membership, I think inserting the one "group name" needed for each host/path would be fairly straight forward.
I would hope that the requested url path would be found in session.server.landinguri but so far I'm testing things in the iRule using variants of [HTTP::host][HTTP::uri] for the lookups.
  • There is a BIG-IP sys db variable that controls this escaping behavior of APM session variables sent to an LDAP query function in APM: apm.ldap.autoescape
    To change it from the CLI,
    tmsh modify sys db apm.ldap.autoescape value disable
    tmsh save sys db
    • TimRiker's avatar
      TimRiker
      That looks exactly like what I want, but unfortunately it does not seem to work.
      Is there anything else I need to do? With this changed and saved, restarted tmm, failed over to another node, failed back, db entry is "disabled" as shown:
      tmsh list sys db apm.ldap.autoescape one-line
      sys db apm.ldap.autoescape { value "disable" }
      And SearchFilter set to something like:
      I still get errors like:
      2022-12-13T20:33:35.393-07:00 xxxx warning apmd[8859]: 01490233:4: /Common/access_xxxx:Common:895b427c: LDAP Module: Cannot find any object in search DN 'ou=people,o=org' matching filter '(&(cn=something)(field=\2a))'
      when session.ldapsearch = "field=*"
      Running BIG-IP 15.1.5.1
      • Lucas_Thompson's avatar
        Lucas_Thompson
        Shoot. Sorry I misunderstood the internal writeup on this. Instead of not escaping itself it looks like it expects *you* to escape it manually. Can you try setting it to "\66\69\65\6C\64\3D\2A"? That should be "field=*".
        You're going to have to double-escape them inside the iRule or policy agent config. TCL gets weird with escaping sometimes. The example I've got from bigip.conf where the variable is being set from a var-assign policy agent to "medusademo" to formulate a search filter is:
        apm policy agent variable-assign /Common/ldaptest_act_variable_assign_ag {
            variables {
                    expression "expr { \"\\\\59\\\\87\\\\FB\\\\A6\\\\AB\\\\1E\\\\D7\\\\40\\\\BE\\\\F8\\\\C7\\\\66\\\\C7\\\\DE\\\\CD\\\\56\" }"
                    varname session.objectguid.foo
        apm policy agent aaa-ldap /Common/ldap_query_bar_act_ldap_query_ag {
            filter "objectGUID=%{session.objectguid.foo}"
            search-dn cn=users,dc=lab,dc=apm,dc=f5test,dc=local
            server /Common/ldapQATest4
            type query
         If it doesn't work at first, packet capture a plaintext LDAP query so you can see what it's sending on the wire, the escaping might not be exactly right.
  • OK, great, it sounds like you've found this setting doesn't fuction correctly in your version. Can you get a support case open so we can investigate further? The DB setting is definitely supposed to disable escaping altogether.
    • TimRiker's avatar
      TimRiker
      Lucas_Thompson
      Where is this db setting documented? It's hard to report "not working as documented" when I can't find any documentation.
  • I've opened support case 00332440 on Dec 19th which, so far, has not gotten any progress.
