25-Feb-2017 15:21
I've been tasked with implementing 2 factor authentication, our team has picked DUO to start the process. There is a DUO/f5 implementation guide that works well, easy. One of the services where we need to use DUO is OWA, issue there is I have a customized login page (using customization templates) the DUO setup is built for the default APM login page.
Is there someone that can help translate the duo setup to a customized page? Duo makes 2 changes with advanced customization. 1. Change header.inc after the last insert ' target="_blank" rel="nofollow">https://api-xzxxxxx.duosecurity.com/frame/hosted/Duo-F5-BIG-IP-v1.js">;
Edit that line with the additional tag shown below and click Save:
The customized login page doesn't have the above line, nor does it use the same credentials table at all.
How can I call the duo Iframe with the customized page?
Thanks!
