11-Sep-2023 07:18
Hi Team,
I have the following scenario and I am looking for ways to implement DUO MFA via APM:
Customer have Priority ERP On-Prem Server with SQL DB, users that connect to Priority login page are authenticated locally with SQL query. I know that SQL query is not supported by big-ip to authenticate users. Now we want to add DUO 2FA to login.
I have followed the arcitle APM Configuration to Support Duo MFA using iRule and was wondering if there is a way to implament the solution with my scenario? I tried with AD Authentication and it works perfect. The problem is as i mentioned users authenticate localy at the server.
The issue is what are my options for First Authentication Factor? I need a way for APM first to pass the user to Priority logon page and after successfull login redirect to DUO 2FA. I have tried to configure "External Logon Page" BUT encountered an endless loop between https:/APM_URL/.my.policy and the logon page.
Can anyone advise which options I have with APM to implament the solution?
Kind Regards,
Max
12-Sep-2023 08:06
I found a solution but getting a hard time to write the right iRule.
I can make API call to the server with iRule sideband Connection to make POST with users credentials.
The flow will be:
https://APM_PORTAL_LOGON/.my.policy ------ > user POST credentials ------- > sideband iRule Event to collect users credentials and POST to server for validation ----- if GOOD proceed to DUO.
Does anyone has iRule sideband connection to validate users credenials ?
13-Sep-2023 01:01
Hi Maxt,
Have you tried using External Logon page ? https://techdocs.f5.com/en-us/bigip-15-0-0/big-ip-access-policy-manager-visual-policy-editor/access-...
15-Sep-2023 06:29
I have tried but there is an issue with customers application, we end up with a redirect loop.
I have wrote an sideband connection iRule to do POST request with users credentials and check the status code from the server.
It works perfectly.
