Technical Forum
APM Certification Study Guides
Nick_Myers
I have an expiring APM certification and need to do some studying before I attempt the exam. My hands on with APM is limited compared to LTM as we have limited use cases for it.
Usually I would book to go on the course and get the classroom material but unfortunately due to Covid spend has been limited.
Does anyone know of any study guides/material for this? There are some good unofficial guides for the LTM path but I cant seem to find anything for this.
Any help would be appreciated.
1 ACCEPTED SOLUTION
Lidev
MVP
MVP
Hello Nick,
Indeed, the BIG-IP APM Specialist Study Guide is not yet developed and published.
Did you read the BIG-IP APM operations guide ? it's very well done and covers the totality of the APM module.
For the material aspect, the best thing is to set up a Lab with a VE F5 and a trial license.
Regards
3 REPLIES 3
Lidev
MVP
MVP
Hello Nick,
Regards
Nick_Myers
Thanks for this, I will take a look at the guide.
Lidev
MVP
MVP
Hi Nick Myers,
If this answer was helpful, please don't forget to mark the answer as "the best" in order to pass your post as resolved.
