APM AD Query fails when using pool
Hi, I need to use the AD Query function at the VPE. For that I created a ADserver object without admin username and password. (If you configure an admin uswername/pwd it fails quering).
Now the issue is that it works if I configure one Active Directory server by using the radio buttion "direct". But when I select a pool and configure several Active Directory servers for redundancy, it fails.
Looking at the log it says:
AD module: ldap_initialize() successful. URI:'ldap://127.7.0.5:389' AD module: Couldn't get ldapHostName for IP address 127.7.0.5. Falling back to reverse DNS record dependency on DNS for AD.
The 127.x.x.x IP addresses appear because you craft a pool. If you use the direct radio button, you will see the IP address of the Active Directory server and it is succcesful.
I am running 11.5.1.hf9.
I need some Active Directory server redundancy, so I was thinking to use a virtual server with loadbalancing across the Active Directory servers. However I get the same errors but then with the IP address of the virtual server.
