VishM's avatar
VishM
Apr 26, 2021
ansible bigip_device_info asm virtual servers empty
I am using ansible bigip_device_info to gather facts for asm using subset "asm-policies", when ran , i see virtual_servers entry is EMPTY, where as when o login to f5 webui i do see a virtual server attached to the ASM policy. Anyone had this issue before ?
        "protocol_independent": "yes",
        "signature_staging": "yes",
        "trigger_asm_irule_event": "disabled",
        "trust_xff": "no",
        "type": "security",
        "use_dynamic_session_id_in_url": "no",
        "virtual_servers": [] ----------------------------------------> i get empty value.
  • Hi Vish,
    Can you post what version of TMOS you're running on? And any chance that the ASM policies are attached using non-standard LTP policies, rather than via the Security tab? (I've noticed that this can mess with the link between ASM policy and its virtual servers)
