Technical Forum
Custom Alert Banner
Ansible bigip_device_facts 2.7
MarkPateman
Trying to initially gather pool member state, but the field STATE within LTM-POOLS does not appear to represent the correct information. e.g. both pool members are healthy and green, but returned STATE is disabled ? If a pool member fails health monitor, STATE is disabled. If I force offline, then STATE is offline.
Don't see other options for monitor or session state on the return pool member data.
How do I know a member is working normally, disabled, forced offline or failing health-monitor from within Ansible, before I start trying to change anything on the F5 and then after to check ?
0 REPLIES 0
