AMQP traffic LB through standard VS. Error = PROXY protocol header signature is not recognized.
Hi. We're trying to LB a cluster with three rabbitMQ (AMQP) servers.
The traffic on a Standard VS should LB to the pool members, the aforementioned rabbitMQ (AMQP) servers. We put the irule for proxy protocol (https://devcentral.f5.com/codeshare/proxy-protocol-initiator).
when CLIENT_ACCEPTED {
set proxyheader "PROXY TCP[IP::version] [IP::remote_addr] [IP::local_addr] [TCP::remote_port] [TCP::local_port]\r\n"
when SERVER_CONNECTED {
TCP::respond $proxyheader
But at the end we received below error message:
"The PROXY protocol header signature was not recognized. (PP 2.1, PP 2.2) "
PROXY protocol has already been enabled on rabbitMQ.conf.
Seems if the PROXY protocol version is not accepted.
Anyone can help with this issue? Thanks in advance.
