wazir's avatar
wazir
Jul 12, 2019
AMQP Cleartext Authentication
Description
The remote Advanced Message Queuing Protocol (AMQP) service supports one or more authentication mechanisms that allow credentials to be sent in the clear.
Solution
Disable cleartext authentication mechanisms in the AMQP configuration in ubuntu or centos machines
disable unencrypted access in the configuration file. >> unencrypted" here refers to client connections.
https://www.rabbitmq.com/ssl.html
Steps of disabling the AMQP:
https://liquidwarelabs.zendesk.com/hc/en-us/articles/360019562832-Disable-cleartext-authentication-option-in-RabbitMQ
The above link used for windows vulnerability. Please help in getting resolution for Centos or Ubuntu configuration file.
