Kevin_Davies_40's avatar
Sep 22, 2017
Advanced Resource Assign Expression Failing
I have a logging agent right before the Advanced Resource Assign with session.custom.* The variable i am testing against is shown. I cannot get the right information to display. I tried ends_with "201" and tried contains "201" but the second one will NOT load and I have no idea why. I do not see those resources on the webtop.
Common:bcb3012f: Logging Agent
Common:bcb3012f: session.custom.rdp.destination is 172.30.7.119
Common:bcb3012f: session.custom.rdp.domain is WORKGROUP
Common:bcb3012f: session.custom.rdp.password is **********
Common:bcb3012f: session.custom.rdp.username is a
Common:bcb3012f: session.custom.version is 801-201
  • Common:f288b920: Connectivity resource '/Common/pa-na' assigned
    Common:f288b920: Webtop '/Common/wt_labs.rededucation.com' assigned
    Common:f288b920: WebtopLinks '/Common/mac_lab_client /Common/nix_lab_client /Common/win_lab_client' assigned
    Common:f288b920: WebtopSections '/Common/clientless /Common/vpn_clients_lab' assigned
    Common:f288b920: Following rule 'fallback' from item 'Palo Alto Resources' to ending 'Allow'
    Common:f288b920: Access policy result: Full
