rogerwow's avatar
rogerwow
Jan 09, 2020
adding a new interface, selfIP and VIP
I've been trying to follow instructions and setup a new interface, selfip and VIP (on the selfip network) and i cant get it to work...
my attempt looks like this:
i've been following:
https://techdocs.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/tmos-routing-administration-11-6-0/2.html
https://support.f5.com/csp/article/K12149
I had the new NIC added to the BigIP VirtualMachine, then i ran
rm –f /var/db/mcpdb*
touch /service/mcpd/forceload
then restarted the box
then ran
f5-swap-eth -w
cat /etc/ethmap
the cat command showed an additional MAC address which i assume was the one that was added (hard to verify)
then i tried to map in a new interface like this:
net self /Common/SomeSelfIp {
  address x.x.x.x/24
  traffic-group /Common/traffic-group-local-only
  vlan /Common/SomeVLAN
net vlan /Common/SomeVLAN {
  interfaces {
    1.9 { }
  tag xxx
however from another machcine on the x.x.x.x/24 network i cant ping this interface..
is there something else i need to do to get it come up?
  • Port lockdown might be a consideration but it shouldn't impact ICMP traffic (ping).
    Are you sure you're using the right physical interface assigned to the vlan?
