Ganesh_Garg's avatar
Ganesh_Garg
Dec 08, 2016
Actual Client IP and Proxy IP in X-Forwarded-For
We have a setup where clients are behind proxy and proxy is the src-ip for LTM, we have enabled X-Forwarded-For and we are getting Proxy-IP in the header, but now the requirement is to have actual client IP as well in the header(Client-IP,Proxy1-IP).
I have enabled the X-forwarded-for on the proxy, but still it seems that the LB is replacing the header with the latest one(proxy-ip)
Please suggest how to get both IP's in the header.
  • Hi Ganesh,
    to consolidate multiple occourences of
    X-Forwarded-For
    headers, you may try the iRule below...
        if { [set x_forwarded [HTTP::header values "X-Forwarded-For"]] ne "" } then {
            HTTP::header remove "X-Forwarded-For"
            HTTP::header insert "X-Forwarded-For" "[join $x_forwarded ", "], [getfield [IP::client_addr] "%" 1]"
            HTTP::header insert "X-Forwarded-For" "[getfield [IP::client_addr] "%" 1]"
    The iRule will collect any existing X-Forwarded-For header values, then remove any existing X-Forwarded-For headers and finally create a new one with the collected values + the current "X-Forwarded-For" value. E.g.:
    Incomming HTTP request headers
    GET / HTTP/1.1
    Host: site.domain.de
    X-Forwarded-For: 1.1.1.1
    X-Forwarded-For: 2.2.2.2, 3.3.3.3
    X-Forwarded-For: 4.4.4.4
    Outgoing HTTP request headers
    GET / HTTP/1.1
    X-Forwarded-For: 1.1.1.1, 2.2.2.2, 3.3.3.3, 4.4.4.4, 5.5.5.5
    Note: Make sure to disable the automatic X-Forwarded-For insert option in your HTTP profile. The insert will be already handled by this iRule...
    Cheers, Kai
  • JG's avatar
    JG
    Would the following fix this for you?
    In Configuration Utility go:
    • Local Traffic ›› Profiles : Services : HTTP ›› your_http_profile
    • and tick the box for "Accept XFF"
    • Fill the field of "XFF Alternative Names"
  • Hi Ganesh,
    I've just checked the provided iRule and it works for me. Please use the iRule below to troubleshoot the issue and post back the resulting logs...
        log local0.debug "Orig XFF: [HTTP::header values "X-Forwarded-For"]"
        log local0.debug "New XFF: [HTTP::header values "X-Forwarded-For"]"
    Note: Also make sure, the
    Insert X-Forwarded-For
    option of your attached HTTP profile is set to
    disable
    Cheers, Kai
