Muhammad_57196's avatar
Muhammad_57196
Jun 24, 2009
active/active F5 LTM
Does anyone have experience of running F5 in active/active configuration. My local F5 personnel recommends me that F5 in active/active pair is not recommended. Whats the issue in running as an active/active pair.
Thanks and Regards,
Dr. Muhammad Malik
  • Hi Dr. MM,
    Your local F5 rep is correct that is not recommended
    Take a look at the following posts
    http://devcentral.f5.com/Default.aspx?tabid=53&forumid=33&postid=58477&view=topic
    http://devcentral.f5.com/Default.aspx?tabid=53&view=topic&postid=29752
    http://devcentral.f5.com/Default.aspx?tabid=53&forumid=5&postid=56476&view=topic
    Thanks,
    CB
