14-Oct-2020 10:22
Hello community,
I would like to know your experiences about TMOS versions installed in production BIGIPs. Currently most of my customers are running TMOS 13.1.3.4 and we have had a very good experience. We try to migrate to 14.1.2.6 but we did not have a good experience. I know that 14.1.2.8 is already released and version 15 is also pretty mature, we have used it for production but in VE editions. However, I would like to know your experiences and recommendations regarding this topic.
I appreciate your feedback.
Best regards,
14-Oct-2020 10:46
Hello Fabian,
We had a lot of problems with asm signature updates in v14.1.2.x and we install Engineering Hotfix on our customers. The bug fixed in 14.1.2.8.
I encountered fewer problems in v15.1.x. We use v15 for new installations.
14-Oct-2020 10:59
Hello eea thanks for your feedback I appreciate it! And question, you've migrated from v13 to v15 without going through 14v? Or starts with new installations directly on v15 and works good?
Regards
14-Oct-2020 11:11
Yes, we direct upgraded from v13 to v15.
You should be careful for iRules, when upgrade to v14.1.x or later.
https://support.f5.com/csp/article/K23237429
14-Oct-2020 11:33
Hello again eaa, thanks alot for your answer.
Best regards,
