02-May-2023 04:11
Hello,
Recently, I found that the MTU settings of the environment are inconsistent
VLAN MTU = 1500
DefaultRoute MTU = 9000
1. Which MTU is the final packet transmission applied to?
2. If I directly change the MTU of the VLAN to 9000, will there be any problem? (affect the service?)
Any Help is appreciate.
02-May-2023 17:16
Hi @Michaelyang
Typically you will not need to change the MTU, but the VLAN MTU is the one for frames leaving the device and onto external switching infrastructure.
