Michaelyang's avatar
Michaelyang
Nov 29, 2022
Solved
About CPU
Hello,
When I was checking CPU usage, I found that there are many types of...
What do they represent...?
The CPU in the dashboard again represents which one in cmmand
Any help would be appreciated!
  • Hi Michaelyang ,
    Under cli, you are looking at each cpu usage for each logical cpu core. If you want to compare it GUI result, you can check it as given below -
    1. Goto - Statistics --> Performance Reports --> Performance Reports
    2. Check System CPU Usage graph
    3. Click the View Detailed Graph where you can see per plane, core cpu usage and compare it with cli o/p
    The one you are seeing in the WEBUI is nothing but overall current usage of Control Plane CPU.
    May I know the F5 model/VM that you are looking at ?
  • Hi Michaelyang ,
    • Michaelyang's avatar
      Michaelyang
      Hi Mayur_Sutare,
      Thanks for your reply.
      I am looking at F5 VE (16.1.2.2)
