SanYang's avatar
SanYang
Oct 04, 2023
Solved
About Bot Defense can't display
Hello,
Has anyone experienced a blank screen when trying to create a "bot defense" profile?
My version is 17.1.0.3...
Any help is appreciate.
  • Are you using any sort of AdBlocker in your browser? That may break BotDefense GUI.
    Try disabling AdBlocker (Not just pausing AdBlocker) should solve the issue.
    Hope that helps!
  • Hi SanYang ,
    What about the other tabs not just " Bot defense page "
    If you have a VE try to upgrade it to v 17.1.0.3 , and look in the same bot defense tab.
    I feel it may related to unknown bug , but in the other side it may works normal with you if you rebooted BIGIP or restarting ( Tomcat & httpd ) services or restarting all of bigip services.
    Hope that helps!
