Technical Forum
1600 LB serial access
mohit123_63342
I am not able to take the serial console of BIG IP 1600 Load balancer.. i have set the baud rate as 19200 at putty. but some junk characters appear. and sometimes end up with a blue screen of my windows.. Any body please help.
Many Thanks...
10 REPLIES 10
Eric_St__John
F5 Employee
F5 Employee
Is this a brand new appliance(no previous configuration)? Are you using the serial cable that was shipped with the appliance?
Thanks,
Eric
nitass
F5 Employee
F5 Employee
have you tried another baud rate? just in case if someone has changed it.
anyway, if you think it is port fault, please open a support case. support team can proceed rma if it is hardware issue indeed.
Eric_St__John
F5 Employee
F5 Employee
An RMA should not be necessary. If there was a previous configuration that is causing issues, you can create a USB bootable thumbdrive and re-image the appliance.
Creating a Bootable USB Thumbdrive:
http://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/bigip_getting_started_guide_10_1_0/bip_gs_app_thumbdrive.html?sr=22475054
If you are on certain versions and the AoM baud rate does not match the baud rate of the appliance you can have issues:
http://support.f5.com/kb/en-us/solutions/public/10000/800/sol10834.html?sr=22474114
Regards,
Eric
mohit123_63342
Hi Eric,
Yes I am using the brand new appliance. And the cable i am using is an extreme DB9 console cable. Not the one in the box.
Is it mandate to use the F5 cable for this.? and i have tried different baud rates as well.
Thanks,
Mohit
mohit123_63342
yes i have tried with other baud rates as well. its a brand new appliance.. i have 2 LB's and not able to take console of both. I guess there is something I am missing..
Eric_St__John
F5 Employee
F5 Employee
The cable must be a null modem cable. You should check the cable you are using, or use the cable supplied with the appliance.
SOL587 - Pinouts for serial terminal cables used to connect the 9-pin serial port on F5 products
http://support.f5.com/kb/en-us/solutions/public/0000/500/sol587.html
Eric
mohit123_63342
yes.. I am using a DB9 cable only.. I am using this appliance for the first time. As i can work with mgmt port. but some cases i need the serial console.
El_Jefe
If you're getting garbage characters, oftentimes, it means a baud / config issue. Make sure you configure putty for 19200, 8-N-1. As the previous poster stated, if that's not working, you need to open a support case.
Eric_St__John
F5 Employee
F5 Employee
I suspect that the cable being used is not a null modem cable and that is the issue. Use the cable that came with the appliance.
Eric
Hamish
Cirrocumulus
Cirrocumulus
Getting chars back suggests its a comms rate problem rather than a null modem problem. No xover would tend to manifest itself as no response as you'd be listening for traffic from the recieving pins...
Make sure your terminal settings agree with the 1600's settings.. You can check them from the lcd screen. Someone may have changed them previously.
H
