on 04-Aug-2010 03:55
An impassioned plea from a devops blogger and a reality check from a large enterprise highlight a growing problem with devops evolutions – not enough dev with the ops.
John E. Vincent offered a lengthy blog on a subject near and dear to his heart recently: devops. His plea was not to be left behind as devops gains momentum and continues to barrel forward toward becoming a recognized IT discipline. The problem is that John, like many folks, works in an enterprise. An enterprise in which not only the existence of legacy and traditional solutions require a bit more ingenuity to integrate but in which the imposition of regulations breaks the devops ability to rely solely on script-based solutions to automate operations.
The whole point of this long-winded post is to say "Don't write us off". We know. You're preaching to the choir. It takes baby steps and we have to pursue it in a way that works with the structure we have in place. It's great that you're a startup and don't have the legacy issues older companies have. We're all on the same team. Don't leave us behind.
John E. Vincent, “No operations team left behind - Where DevOps misses the mark”
But it isn’t just legacy solutions and regulations slowing down the mass adoption of cloud computing and devops, it’s the sheer rate of change that can be present in very large enterprise operations.
Scripted provisioning is faster than the traditional approach and reduces technical and human costs, but it is not without drawbacks. First, it takes time to write a script that will shift an entire, sometimes complex workload seamlessly to the cloud. Second, scripts must be continually updated to accommodate the constant changes being made to dozens of host and targeted servers.
"Script-based provisioning can be a pretty good solution for smaller companies that have low data volumes, or where speed in moving workloads around is the most important thing. But in a company of our size, the sheer number of machines and workloads we need to bring up quickly makes scripts irrelevant in the cloud age," said Jack Henderson, an IT administrator with a national transportation company based in Jacksonville, Fla.
More aggressive enterprises that want to move their cloud and virtualization projects forward now are looking at more advanced provisioning methods
Server provisioning methods holding back cloud computing initiatives
Scripting, it appears, just isn’t going to cut it as the primary tool in devops toolbox. Not that this is any surprise to those who’ve been watching or have been tackling this problem from the inevitable infrastructure integration point of view. In order to accommodate policies and processes specific to regulations and simultaneously be able to support a rapid rate of change something larger than scripts and broader than automation is going to be necessary.
You are going to need orchestration, and that means you’re going to need integration. You’re going to need Infrastructure 2.0.
In order to properly scale automation along with a high volume of workload you need more than just scripted automation. You need collaboration and dynamism, not codified automation and brittle configurations. What scripts provide now is the ability to configure (and update) the application deployment environment and – if you’re lucky – piece of the application network infrastructure on an individual basis using primarily codified configurations. What we need is twofold. First, we need to be able to integrate and automate all applicable infrastructure components. This becomes apparent when you consider the number of network infrastructure components upon which an application relies today, especially those in a highly virtualized or cloud computing environment.
Second is the ability to direct a piece of infrastructure to configure itself based on a set of parameters and known operatio... – at the time it becomes active. We don’t want to inject a new configuration every time a system comes up, we want to modify on the fly, to adapt in real-time, to what’s happening in the network, in the application delivery channel, in the application environment. While it may be acceptable (and it isn’t in very large environments but may be acceptable in smaller ones) to use a reset approach, i.e. change and reboot/reload a daemon to apply those changes, this is not generally an acceptable approach in the network. Other applications and infrastructure may be relying on that component and rebooting/resetting the core processes will interrupt service to those dependent components. The best way to achieve the goal desired – real-time management – is to use the APIs provided to do so.
On top of that we need to be able to orchestrate a process. And that process must be able to incorporate the human element if necessary, such as may be the case with regulations that require approvals or “sign-offs”. We need solutions that are based on open-standards and integrate with one another in such a way as to make it possible to arrive at a solution that can serve an organization of any size and any age and at any stage in the cloud maturity model.
Right now devops in practice is heading down a path that relegates it to little more than automation operators, which is really not all that much different than what the practitioners were before. Virtualization and cloud computing have simply raised their visibility due to the increased reliance on automation as a means to an end. But treating automated operations as the end goal completely eliminates the “dev” in “devops” and ignores the concept of an integrated, collaborative network that is not a second-class citizen but a full-fledged participant in the application lifecycle and deployment process. That concept is integral to the evolution of highly virtualized implementations toward a mature, cloud-based environment that can leverage services whether they are local, remote, or a combination of both. Or that change from day to day or hour to hour based on business and operational conditions and requirements.
The core concept behind infrastructure 2.0 is collaboration between all applicable constituents – from the end user to the network to the application infrastructure to the application itself. From the provisioning systems to the catalog of services to the billing systems. It’s collaborative and dynamic, which means adaptive and able to change the way in which policies are applied – from routing to switching to security to load balancing – based on the application and its right-now needs. Devops is – or should be - about enabling that integration. If that can be done with a script, great. But the reality is that a single script or set of scripts that focus on the automation of components rather than systems and architectures is not going to scale well and will instead end up contributing to the diseconomy of scale that was and still is the primary driver behind the next-generation network.
Scripts are also unlikely to address the very real need to codify the processes that drive an enterprise deployment, and do not take into consideration the very real possibility that a new deployment may need to be “backed-out” if something goes wrong. Scripts are too focused on managing configurations and not focused enough on managing the infrastructure. It is the latter that will ultimately provide the most value and the means the which the network will be elevated to a first class citizen in the deployment process.
Infrastructure 2.0 is the way in which organizations will move from aggregation to automation and toward the liberation of the data center based on full stack interoperability and portability. A services-based infrastructure that can be combined to form a dynamic control plane that allows infrastructure services to be integrated into the processes required to not just automate and ultimately orchestrate the data center, but to do so in a way that scales along with the implementation.
Collaboration and integration will require development, there’s no way to avoid that. This should be obvious from the reliance on APIs (Application Programming Interface), a term which if updated to reflect today’s terminology would be called an ADI (Application Development Interface). Devops needs to broaden past “ops” and start embracing the “dev” as a means to integrate and enable the collaboration necessary across the infrastructure to allow the maturation of emerging data center models to continue. If the ops in devops isn’t balanced with dev, it’s quite possible that like many cross-discipline roles within IT, the concept of devops may have to fork in order to continue moving virtualization and cloud computing down its evolutionary path.
NOTE: Edited 8/4/2010 after a conversation with one of the "founding fathers" of devops, John Willis, to note that it's not the devops movement per se that's headed down the automation and scripts path, but devops in practice. As he notes in one of his discussions of devops, there's a lot more to devops than just automation. The "tear down the walls" between operations and development should be a familiar one to those who have embraced application delivery as a means to integrate these two disparate and yet complementary roles.
Related Posts |
