31-Oct-2022 05:00 - edited 14-Nov-2022 14:32
This article is part of a series on implementing Orchestrated Infrastructure Security. It includes High Availability and the protection of critical assets using Virtual Cisco Firepower. It is assumed that SSL Orchestrator is already deployed, and basic network connectivity is working.
If you need help setting up SSL Orchestrator refer to this Dev/Central article series or the CloudDocs Deployment Guide here
This article focuses on using SSL Orchestrator as a tool to assist with simplifying Change Management processes, procedures and shortening the duration of the entire process.
Cisco Firepower backup files can be downloaded from here from GitLab
Please forgive me for using SSL and TLS interchangeably in this article.
A video demo of this Dev/Central article is available HERE
This article is divided into the following high level sections:
Part1 (available here)
Part 2 (available here)
Adapter 1 is for Management
Adapter 2 is for the Diagnostic interface
Adapter 3 corresponds to Firepower interface 0/0
Adapter 4 corresponds to Firepower interface 0/1
The Firepower network settings should look like this
For a Layer 2 deployment like this use Ethernet0/0 and Ethernet0/1 to Create an Inline Set
Create an Inline Set (Layer 2 bridge). Click Add Inline Set. Give it a name, inlineset1 in this example. Move eth0< - >eth1 to the Selected Interface Pair. Click OK
Repeat these steps if configuring SSL Orchestrator deployed with High Availability
Configure ESX Networking
Create a Port Group for the following
Network connectivity to the North (connected to BIG-IP interfaces)
Network connectivity to the South (connected to BIG-IP interfaces)
Service Egress to Firepower1
Service Ingress from Firepower1
Service Egress to Firepower2
Service Ingress from Firepower2
A new Topology will be used to test the Service after maintenance is performed. This Topology can be re-used in the future
From the BIG-IP Configuration Utility click Add
Scroll to the bottom and click Next
Give it a name, Topology_Staging
Select L2 Inbound as the Topology then click Save & Next
Click Save & Next
Click Save & Next
Click Add. A new Service Chain is needed so we can remove Firepower1 from the Production Service and add it here
Give the Service Chain a name, Click Save
Note: The Service will be added to this Service Chain later
Click Save & Next
Click Add
Set Conditions to Client IP Subnet Match
Enter the Client IP and mask, 10.1.11.52/32. Click New
Set the SSL Proxy Action to Intercept
Set the Service Chain to the one created previously
Click OK
Note: This rule is so a single client computer (10.1.11.52) will match and can be used for testing. In the All Traffic default rule set the SSL Proxy Action to Bypass
Select Save & Next
Set the Source Address to 10.1.11.52/32. Set the Destination Address/Mask to 10.4.11.0/24. Set the port to 443
Select the VLAN for your Ingress Network and move it to Selected
Set the L7 Profile to Common/http
Click Save & Next
Select Save & Next
Click Deploy
Check the statistics on the Firepower device we will be performing maintenance on. It’s “Firepower1” in this example. Connect to the CLI via SSH. At the prompt enter ‘capture-traffic’. Select the correct ‘inlineset’ (2 in this example) and hit Enter for no tcpdump options:
You should see an output similar to this
This Firepower device is actively processing connections
Back to the SSL Orchestrator Configuration Utility. Click Services then the Service name
Click the pencil icon
Click the pencil icon for Firepower2
Set the ratio to 65535, click Done
Click Save & Next
Click OK
Click Deploy
Click OK
With the Weight Ratio change there should be no active connections. It should look like this
Note: The connections above represent the health checks from SSL Orchestrator to the inline Service
From the SSL Orchestrator Configuration Utility. Click Services then the Service name
Delete Firepower1
Click Save & Next
Click OK
Click Deploy
Click OK
Proceed to Part 2
