on 09-Mar-2023 05:00
In organizations today, application infrastructure deployment involves teams such as platform teams, Ops teams, and dev teams all working together to ensure consistency and compliance. This is no easy task as because of siloed teams and expertise and deploying application infrastructure is time-consuming. Platform teams typically address this challenge with automation and by enabling their ops team and developers with self-service infrastructure – which abstracts most steps of deployment. HashiCorp Terraform No-Code Provisioning enables self-service of BIG-IP infrastructure as it allows the platform teams to create and maintain a library of pre-built Terraform modules that can be used by ops teams and developers to deploy multi-cloud BIG-IP infrastructure and services for their applications. This help to ensure consistency and reduce the amount of time organizations need to set up and configure infrastructure.
Taking this one step further, the Terraform no-code modules enable infrastructure teams to streamline automation by combining CI/CD pipelines, any custom scripts, and other automation tools in the deployment chain allowing developers and operations teams to deploy F5 application services and infrastructure anywhere with a few clicks from the Terraform Cloud GUI – all while maintaining compliance.
No-code provisioning in Terraform Cloud lets users deploy infrastructure resources without writing Terraform configuration. This lets organizations provide a self-service model to developers with limited infrastructure knowledge and a way to deploy the resources they need.
You need the following:
Fork the example GitHub repository https://github.com/f5businessdevelopment/terraform-aws-bigip-nocode
Make sure you have variables defined as shown below
variable "prefix" {
description = "provide some prefix for deployment"
variable "region" {
description = "AWS region you can define example is us-west-2 "
variable "allow_from" {
description = "IP Address/Network to allow traffic from your machine (i.e. 192.0.2.11/32)"
These variable definitions facilitate the exposure of parameters while deploying the BIG-IP instance, you can add/delete any new parameters you need to expose.
First, create a tag for your module. Tags are required to create a release on the GitHub repository, Terraform Cloud will use this tag to register the module.
git tag 1.0.0
git push –tags
Once your release is ready on the Github repository
It will take a couple of seconds to Publish the module, once done you will see the screen below as shown. Now you are ready to use the module, to deploy the BIG-IP instance you click on the Provision workspace tab.
Once we have the No-Code module published on Terraform Cloud we are ready to use it.
BIG-IP instance will be ready with the Management IP address and password for you.
Finally, the Infrastructure team can help to ensure the security and compliance of the infrastructure deployed using the Terraform No-Code Provisioning by implementing security best practices controls and monitoring.
Reference Video
