Technical Articles
F5 SMEs share good practice.
Jodie_Putrino_2
Historic F5 Account
Release Announcement
06 July 2016
We are pleased to announce the release of v1.0.0 of the F5 Python SDK. This is the first stable release of the SDK.
Summary
This release is not backwards compatible because support for aliased resources has been removed. This means that
x = y.create(...)
 no longer changes both
x
 and
y
.  Instead, x is the created configuration object and
y
 is a creation factory.
The release also incorporates several important bug-fixes, noted below.
Release Highlights
The following bug-fixes are included in this release. Most importantly, the SDK now allows a minimum BIG-IP® version of `11.5.0` and has no maximum version.
* #523 Add support for ltm.data_group
* #491 allows all versions >= 11.5.0 by default
* #492 fix the sys ntp resource
* #411 calling `create` and `load` on Resources now returns a new instance of the relevant resource (a factory pattern); this fixes an aliasing bug
* #497 New API endpoints for GTM datacenters and iRules
* This release fixes multiple type-errors in the concrete subclasses.
* #533 Turns off `_check_generation` because it is buggy.
* #521 migrate clustering to support non-aliased pattern
See the changelog for the full list of changes in this release.
Open Issues
See the project issues page for a full list of open issues in this release.
- The F5 OpenStack Product Team and F5 Python SDK Contributors
Comments
Saravanan_M_K
F5 Employee
F5 Employee
The python SDK is based on which version of python?--Python 2.7.x or Python 3.4.x?
Jodie_Putrino_2
Historic F5 Account
Great question! We're working from python 2.7.x.
Ricardo_04_1413
Could be possible to get simple examples of authentication using this library? I've hit several issues when trying to use it as explained in your examples, as the SSL library built in on Python 2.x lacks support to manage SNI.
And to properly handle certificate validations you need to start calling urrlib3.PoolManager() and addressing http.request('GET'...) and http.request('POST'...) and the like.
Which it is supposed you should not need to do with this library.
On the other hand, trying to use Python3 took me to a scenario where the F5 library is calling the urlparse module, which has been renamed in Python 3 to urrlib.parse. My Python 3 interpreter can't find it, so this F5 library can't be used with Python 3 as it is today.
Or may be I am missing something...
Thanks so much in advance.
JRahm
Community Manager
Community Manager
could you provide specific details on what you are trying to do? For example, are you trying to connect to a BIG-IP through an IP that is hosting multiple SSL fqdns?
Version history
Last update:
‎05-Jun-2023 15:59
Updated by:
