Manage F5 BIG-IP FAST with Terraform (Part 3 - Manage multiple AWAF policies based on HTTP criteria)
The goal of this use case is to deploy a new HTTPS application with F5 BIG-IP Advanced Web Application Firewall policy on F5 BIG-IP device using F5 BIG-IP Application Services Templates Terraform resources. Web application firewall policies and pools will be applied based on hostname or uri path.
This configuration can be applied in a public cloud when there is only one public IP and you want to manage different applications and the associated Web Application Firewall policy. The selection can be based on hostname or uri.
Table of Content
Table of Contents
Workflow to manage multiple AWAF policies and pools based on HTTP criteria
First, create 4 files:
- main.tf
- variables.tf
- inputs.auto.tfvars
- providers.tf
variables.tf
variable "bigip" {}
variable "username" {}
variable "password" {}
variable "policyname" {
type = string
default = ""
variable "partition" {
type = string
default = "Common"
inputs.auto.tfvars
bigip = "10.1.1.9:443"
username = "admin"
password = "whatIsYourBigIPPassword?"
partition = "Common"
policyname = "myApp6_ltm_policy"
providers.tf
terraform {
required_providers {
bigip = {
source = "F5Networks/bigip"
version = ">= 1.16.0"
provider "bigip" {
address = var.bigip
username = var.username
password = var.password
main.tf
resource "bigip_waf_policy" "app1" {
provider = bigip
description = "WAF Policy for App1"
name = "app1"
partition = var.partition
template_name = "POLICY_TEMPLATE_RAPID_DEPLOYMENT"
application_language = "utf-8"
enforcement_mode = "blocking"
server_technologies = ["Apache Tomcat", "MySQL", "Unix/Linux"]
resource "time_sleep" "wait_a" {
create_duration = "10s"
depends_on = [bigip_waf_policy.app1, bigip_waf_policy.app2]
resource "time_sleep" "wait_b" {
depends_on = [bigip_waf_policy.restricted]
resource "bigip_waf_policy" "app2" {
provider = bigip
description = "WAF Policy for App2"
name = "app2"
server_technologies = ["Apache Tomcat", "MySQL", "Unix/Linux", "MongoDB"]
resource "bigip_waf_policy" "restricted" {
provider = bigip
description = "WAF Policy for restricted areas"
name = "restricted"
depends_on = [time_sleep.wait_a]
resource "bigip_waf_policy" "default" {
provider = bigip
description = "desfault WAF Policy"
name = "default"
depends_on = [time_sleep.wait_b]
resource "bigip_ltm_pool" "pool1" {
provider = bigip
name = "/${var.partition}/pool1"
allow_nat = "yes"
allow_snat = "yes"
load_balancing_mode = "round-robin"
resource "bigip_ltm_pool_attachment" "pool1-member" {
pool = bigip_ltm_pool.pool1.name
node = "10.1.10.120:80"
resource "bigip_ltm_pool" "pool2" {
provider = bigip
name = "/${var.partition}/pool2"
allow_nat = "yes"
allow_snat = "yes"
resource "bigip_ltm_pool_attachment" "pool2-member" {
pool = bigip_ltm_pool.pool2.name
node = "10.1.10.121:80"
resource "bigip_ltm_pool" "pool_restricted" {
provider = bigip
name = "/${var.partition}/pool_restricted"
allow_nat = "yes"
allow_snat = "yes"
module "consolidated_vips" {
source = "github.com/f5devcentral/fast-terraform//multiple_waf_policies?ref=v1.0.0"
providers = {
bigip = bigip
name = var.policyname
rules = [
name = "WWW1_App"
hostname = ["www1.f5demo.com", "app1.f5demo.com"]
policy = bigip_waf_policy.app1.name
pool_name = bigip_ltm_pool.pool1.name
name = "WWW2_App"
hostname = ["www2.f5demo.com"]
policy = bigip_waf_policy.app2.name
pool_name = bigip_ltm_pool.pool2.name
name = "restricted"
path = ["/restricted", "/admin", "/hr"]
policy = bigip_waf_policy.restricted.name
pool_name = bigip_ltm_pool.pool_restricted.name
default_policy = bigip_waf_policy.default.name
depends_on = [bigip_waf_policy.app1, bigip_waf_policy.app2, bigip_waf_policy.restricted, bigip_waf_pol
icy.default]
resource "bigip_fast_https_app" "this" {
application = "myApp6"
tenant = "scenario6"
virtual_server {
ip = "10.1.10.226"
port = 443
tls_server_profile {
tls_cert_name = "/Common/default.crt"
tls_key_name = "/Common/default.key"
snat_pool_address = ["10.1.10.50", "10.1.10.51", "10.1.10.52"]
endpoint_ltm_policy = ["${module.consolidated_vips.ltmPolicyName}"]
security_log_profiles = ["/Common/Log all requests"]
waf_policy.default, module.consolidated_vips.ltmPolicyName]
here is how run it:
$ terraform init -upgrade
$ terraform plan -out scenario6
$ terraform apply "scenario6"
Demo Video
Resources
Terraform Registry documentation
Article Series
Manage F5 BIG-IP FAST with Terraform (Part 1 - Create multiple HTTP applications in the same tenant)
Published Nov 28, 2022
Version 1.0Patrick_Echeverria
Ret. Employee
Joined November 17, 2005
Fouad_Chmainy
Employee
Joined May 16, 2019
Guillermo_Gonzalez
Employee
Joined November 28, 2022
