Manage F5 BIG-IP FAST with Terraform (Part 1 - Create multiple HTTP applications in the same tenant)
This is a green field scenario. Here we will use F5 BIG-IP FAST Terraform resources to create multiple HTTP applications in the same tenant.
Table of Content
Table of Contents
Workflow for creating multiple HTTP applications in the same tenant
First, we will create 5 files in ~/app1 to deploy a first application myApp3 in tenant scenario3:
- main.tf
- variables.tf
- inputs.tfvars
- outputs.tf
- providers.tf
variables.tf
variable bigip {}
variable bigip {}
variable username {}
variable password {}
inputs.tfvars
bigip = "10.1.1.9:443"
username = "admin"
password = "yYyYyYy"
providers.tf
terraform {
required_providers {
bigip = {
source = "F5Networks/bigip"
version = ">= 1.16.0"
provider "bigip" {
address = var.bigip
username = var.username
password = var.password
main.tf
resource "bigip_fast_http_app" "app1" {
application = "myApp3"
tenant = "scenario3"
virtual_server {
ip = "10.1.10.223"
port = 80
pool_members {
addresses = ["10.1.10.120", "10.1.10.121", "10.1.10.122"]
port = 80
snat_pool_address = ["10.1.10.50", "10.1.10.51", "10.1.10.52"]
load_balancing_mode = "least-connections-member"
monitor {
send_string = "GET / HTTP/1.1\\r\\nHost: example.com\\r\\nConnection: Close\\r\\n\\r\\n"
response = "200 OK"
outputs.tf
output "configJSON" {
value = bigip_fast_http_app.app1
sensitive = true
here is how run it:
$ cd ~/app1
$ terraform init -upgrade
$ terraform plan -var-file=inputs.tfvars -out scenario3app1
$ terraform apply "scenario3app1"
Second, we will create 5 files in ~/app2 to deploy a first application myApp3-1 in tenant scenario3::
- main.tf
- variables.tf
- inputs.tfvars
- outputs.tf
- providers.tf
variables.tf
variable bigip {}
variable bigip {}
inputs.tfvars
username = "admin"
providers.tf
terraform {
bigip = {
provider "bigip" {
address = var.bigip
main.tf
resource "bigip_fast_http_app" "app2" {
application = "myApp3-1"
virtual_server {
ip = "10.1.10.233"
port = 80
pool_members {
addresses = ["10.1.10.130", "10.1.10.131", "10.1.10.132"]
port = 80
snat_pool_address = ["10.1.10.53", "10.1.10.54", "10.1.10.55"]
load_balancing_mode = "round-robin"
monitor {
response = "302"
outputs.tf
output "configJSON2" {
value = bigip_fast_http_app.app2
sensitive = true
here is how run it:
$ cd ~/app2
$ terraform plan -var-file=inputs.tfvars -out scenario3app2
$ terraform apply "scenario3app2"
Demo Video
Resources
Terraform Registry documentation
Article Series
Published Nov 28, 2022
Version 1.0Patrick_Echeverria
Ret. Employee
Joined November 17, 2005
Fouad_Chmainy
Employee
Joined May 16, 2019
Guillermo_Gonzalez
Employee
Joined November 28, 2022
