Technical Articles
F5 SMEs share good practice.
Steve_McCarthy_
Historic F5 Account
Introduction
F5 Local Traffic Manager (LTM) has always provided customers with the ability to optimize their network deployment by providing tools that can observe network traffic which also allow the administrator to configure various actions to take based on those observations.  This is embodied in the fundamental concept of a virtual server, which groups traffic into pools based on observed IP addresses, ports, and DNS names, and furthered by extensions like iRules, which provide a tremendous amount of flexibility and customizability.
For HTTP traffic up until BIG-IP 11.4.0, the HTTP Class module provided the ability for an administrator to match various parts of an HTTP transaction using regular expressions, and specify an associated action to take.  These include actions such as inserting or removing a header, sending a redirect, or deciding to which vlan or pool a request should be forwarded.  This was a flexible approach, but regular expression processing can be performance intensive, serial evaluation can get bogged down when the number of conditions increases, and sometimes proper coverage would require the administrator to configure specific ordering of evaluation.
With the growth of traffic on the internet, and the explosion of HTTP traffic in particular, organizations are increasingly in need of more sophisticated tools which can observe traffic more in-depth and execute actions with good performance.
LTM Policy
0151T000003d6PYQAY.pngLTM Policy first appeared in BIG-IP 11.4.0 as a flexible and high-performance replacement for HTTP Class.  Additional capabilities and features have been continuously added since that time.  At its core, LTM Policy is a data-driven rules engine which is tightly integrated with the Traffic Management Microkernel (tmm).
One of the big improvements brought by LTM Policy is the accelerated and unique way that it can evaluate all conditions in parallel.  When one or more policies are applied to a virtual server, they go through a compilation step that builds a combined, high-performance internal decision tree for all of the rules, conditions, and actions.  This optimized representation of a virtual server's policies guarantees that every condition is only evaluated once and allows for parallel evaluation of all conditions, as well as other performance boosts, such as short-circuit evaluation.
Another improvement is that conditions can observe attributes from both the request and the response, not just the request.  Unlike HTTP Class, where its first-match-win could lead to ordering issues, LTM Policy can trigger on the first matching condition, all matches, the most specific match, or execute a default action when there are no condition matches.
Policies
What is a policy?  A policy is a collection of rules, and is associated with a matching strategy, aspects the policy requires, and other aspects the policy controls.
Every rule in a policy has a set of conditions and a set of actions, where either set may be empty.
Conditions
Conditions describe the comparisons that occur when traffic flows through a virtual server.  The properties available to a condition depend on what aspect the policy requires.  (See Conditions chart below.)  For example, if a policy requires the http aspect, then HTTP-specific entities like headers, cookies, URI can be used in comparisons.
If the policy requires this aspect:Then these Operands are available:Some of the properties that are available for comparison in conditions:
none
cpu-usage
1, 5, 15 minute load average
tcptcp
(+ all above)
IP address, port, mss
httpgeoipgeographic region associated with IP address
 http-uridomain, path, query string
 http-methodHTTP method, e.g. GET, POST, etc.
 http-versionversions of HTTP protocol
 http-statusnumeric and text response status codes
 http-hosthost and port value from Host: header
 http-headerheader name
 http-refererall components of Referer: URI
 http-cookiecookie name
 http-set-cookieall components of Set-Cookie
 http-basic-authusername, password
 http-user-agent
(+ all above)
browser type, version; device make, model
client-sslclient-sslprotocol, cipher, cipher strength
ssl-persistencessl-extensionserver name, alpn, npn
 ssl-certcommon-name from cert
Actions
Actions are commands which are executed when the associated conditions match.  As with conditions, the actions available to a policy depend on which aspects the policy controls.  (See Action chart below.)  For example, if a policy controls the forwarding aspect, then forwarding-specific actions, such as selecting a pool, virtual server, or vlan are available.
A default rule is a rule which has no conditions - and is therefore considered to always be a match - plus one or more actions.  A default rule is typically ordered such that it would be the last rule evaluated.  In policies with a first-match or best-match strategy (see below), the default rule is only run when no other rules match;  policies with an all-match strategy will always execute default rule actions.
If the policy
Controls
this aspect:
Then these
Targets
are available:
Which enables you to specify some of these Actions:
(none specified)
ltm-policydisable LTM Policy
 httpenable/disable HTTP filter
http-uri
replace path, query string, or full URI
 http-hostreplace Host: header
 http-headerinsert/remove/replace HTTP  header
 http-refererinsert/remove/replace Referer:
 http-cookieinsert/remove Cookie in request
 http-set-cookieinsert/remove Set-Cookie in response
 logwrite to system logs
 tclevaluate Tcl expression
 tcp-nagleenable/disable Nagle's algorithm
forwardingforwardpick pool, vlan, nexthop, rateclass
 http-replysend redirect to client
cachingcacheenable/disable caching
compressioncompressenable/disable compression
 decompressenable/disable decompression
classificationpemclassify traffic category/application
request-adaptationrequest-adaptenable/disable content adaptation through internal virtual server
response-adaptationresponse-adaptenable/disable content adaptation through internal virtual server
server-sslserver-sslenable/disable server ssl
persistencepersist
Select persistence (e.g. cookie,
source address, hash, etc)
Strategy
All policies are associated with a strategy, which determines the behavior when multiple rules have matching conditions.  As their titles suggest, the First Match strategy will execute the actions for the first rule that matches, All Match strategy will execute the actions for all rules which match, and Best Match will select the rule which has the most specific match.  The most specific match is determined by comparing the rules for the number of conditions that matched, the longest matches, or the matches which are deemed to be more significant.
Multiple policies can be applied to a virtual server.  The only restriction is that each aspect of the system (e.g. forwarding, caching, see Actions table) may only be controlled by one policy.  This is a reasonable restriction to avoid ambiguous situations where multiple policies controlling the same aspect match but specify conflicting actions.
LTM Policy and iRules
iRules are an important and long-standing part of the BIG-IP architecture, and pervasive throughout the product.  There is some overlap between what can be controlled by LTM Policy and iRules, not surprisingly that most of the overlap is in the realm of HTTP traffic handling.   And just about anything that is possible in LTM Policy can also be written as an iRule.
LTM Policy is a structured, data-driven collection of rules.  iRules and Tcl are more of a general purpose programming language which provide lots of power and flexibility, but also require some programming skills.  Because policies are structured and can be created by populating tables in a web UI, it is more approachable for those with limited programming skills.
So, when to use LTM Policy and when to use iRules?  As a general rule, where there is identical functionality, LTM Policy should be able to offer better performance.  There are situations where LTM Policy may be a better choice.
  • when rules need to span different events, (e.g. a rule that considers both request and response)
  • dealing with HTTP headers and cookies (e.g. LTM Policy has more direct access to internal HTTP state)
  • when there are large number of conditions (pre-compiled internal decision trees can evaluate conditions in parallel)
  • when conditions have a lot of commonality
For supported events (such as HTTP_REQUEST or HTTP_RESPONSE) , LTM Policy evaluation occurs before iRule evaluation.  This means that it is possible to write an iRule to override an LTM Policy decision.
LTM Policy leverages standard iRule functions
Beginning with releases in 2015, selected LTM Policy actions support Tcl command substitutions and the ability to call standard iRule commands .   The intention is to empower the administrator with quick, read-only access to the runtime environment.  For example, it is possible to specify an expression which includes data about the current connection, such as [HTTP::uri ] which gets substituted at runtime to the  URI value of the current request.
Tcl support in LTM Policy is not intended as a hook for general purpose programming, and can result in an error when making calls which might have side effects, or calls which might cause a processing delay.  There is also a performance trade-off to consider as well, as Tcl’s flexibility comes with a runtime cost.
Below is a summary of actions which support Tcl expressions:
TargetAction(s)ParameterNote
http-urireplacevalueFull URI
  pathURI path component
  query stringURI query string component
http-headerinsertvalueArbitrary HTTP header
 replacevalue
http-cookieinsertvalueCookie: header
http-hostreplacevalueHost: header
http-refererreplacevalueReferer: header
http-set-cookieinsertvalueSet-Cookie: header
  domain
  path
log messageWrite to syslog
tcl*setvarexpressionset variable in Tcl runtime environment
http-reply*redirectlocationredirect client to location
*This action has supported Tcl expressions since BigIP 11.4.
While a comprehensive list of valid Tcl commands is beyond the scope of this document, it should be noted that not every Tcl command will be valid at any given time. Most standard iRule commands are associated with a tmm event , as are LTM Policy actions.  For example, in the LTM Policy event request, iRule commands which are valid in the context of HTTP_REQUEST event will validate without error.  A validation error will be raised if one attempts to use iRule commands that are not valid in the current event scope.  For example, in an LTM Policy action associated with the request (i.e. HTTP_REQUEST) event context, specifying an expression like [HTTP::status] , which is only valid in a response event context, will not pass the validation check.
iRules support LTM Policy
There are several iRule commands defined which can be used to access information about policies attached to the virtual server.
  • POLICY::controls - iRule command which returns details about the policy controls for the virtual server the iRule is enabled on
  • POLICY::names - iRule command which returns details about the policy names for the virtual server the iRule is enabled on.
  • POLICY::rules - iRule command which returns the policy rules of the supplied policy that had actions executed.
  • POLICY::targets - iRule command which returns or sets properties of the policy rule targets for the policies associated with the virtual server that the iRule is enabled on
What can I do with it?
Sky's the limit.
Here are some sample tasks and LTM Policies that could be used to implement them.  Keep in mind that the policy definitions shown below, which at first glance appear to be more complicated than an equivalent iRule, are generated by a more friendly, web-based UI.  The web UI allows the policy author to select valid options from menus, and build up a policy with little worry about programming and proper syntax.
TaskConfiguration
If system load average over the last minute is above 5, then disable compression.  (This example assumes compression is competing for CPU cycles, and would not apply to scenarios where hardware compression is available.)
Demonstrates cpu load conditions and ability to control compression.
ltm policy /Common/load-avg {
    controls { compression }
    requires { http }
    rules {
        rule-1 {
            actions {
                0 {
                    compress
                    disable
            conditions {
                0 {
                    cpu-usage
                    last-1min
                    greater
                    values { 5 }
            ordinal 1
    strategy /Common/first-match
If request is coming from California, forward it to pool pool_ca, and if the request comes from Washington, direct it to pool_wa.  Otherwise forward to my-default-pool.
Demonstrates geo-IP conditions, actions to forward to specific pool, and a default rule.
ltm policy /Common/policy-sa {
    controls { forwarding }
    requires { http }
    rules {
        defaultrule {
            actions {
                0 {
                    forward select
                    pool /Common/my-default-pool
            ordinal 3
        rule-1 {
            actions {
                0 {
                    forward select
                    pool /Common/pool_ca
            conditions {
                0 {
                    geoip region-name
                    values { California }
            ordinal 1
        rule-2 {
            actions {
                0 {
                    forward select
                    pool /Common/pool_wa
            conditions {
                0 {
                    geoip region-name
                    values { Washington }
            ordinal 2
If the request was referred by my-affiliate.com and the response contains an image, set a cookie containing the current time.
Example of a policy which spans both request and response, and uses Tcl command substitution for a value.
ltm policy /Common/affiliate {
    requires { http }
    rules {
        rule-1 {
            actions {
                0 {
                    http-set-cookie
                    response
                    insert
                    name MyAffiliateCookie
value "tcl:[clock format [clock seconds] -format %H:%M:%S]"
            conditions {
                0 {
                    http-referer
                    contains
                    values { my-affiliate.com }
                1 {
                    http-header
                    response
                    name Content-type
                    starts-with
                    values { image/ }
            ordinal 1
Some rules of thumb
While there are certainly exceptions to any rule, the following are some general usage guidelines.
  • The maximum number of rules across active policies is limited by memory and cpu capability, but more than a thousand is starting to be a lot .
  • Using Tcl command substitutions in actions can have performance implications; the more Tcl, the more performance impact.
  • Only use Tcl commands that read and quickly return data; avoid those that change internal state or cause any delays.
Conclusion
LTM Policy is a powerful, flexible, and high-performance tool that administrators can leverage for application deployment.  Its table-driven user interface requires very little in the way of programming experience, and new capabilities have been added continuously with each release.
Comments
Vsevolod_Petrov
Thanks for the article Steve! Do you know if it possible to create tcp-only policy without http?
Steve_McCarthy_
Historic F5 Account
Quick answer: no. As LTM Policy has descended from HTTP Class, it remains pretty focused at the HTTP layer. So the TCP support currently includes the conditions and actions listed above.
dso2_161782
Very promising! The article mentions in the table below Actions and shows in the pictures "persistence" as an available Control. Much wished, I hope this will be soon available for release.
Luis_Araujo_560
Great Article. Will help me a lot. Congrats!!!!
OTS02_109465
Thanks for the great article Steve. It's the kick-starter I needed to start monkeying around with policies.
Opher_Shachar_6
Thanks Steve for a very informative article. As dso2 asks, when (i.e. what HF) will "persist" as a target be available? Thanks.
Steve_McCarthy_
Historic F5 Account
Well you eagle-eyed folks did notice persistence as an aspect of the system that can be controlled by LTM Policy in the screenshot. Please realize that I don't speak in an official capacity as far what features will be available in which release. So without making any specific commitment or promise, you may have luck looking for it in our next release later spring / early summer 2015.
Walter_Kacynski
Has the geoip option only been added in 11.6?
Steve_McCarthy_
Historic F5 Account
GeoIp conditions were first supported in LTM Policy in version 11.6.
Simon_Blakely
F5 Employee
F5 Employee
How can you use a tcl expression (such as tcl:[IP::client_addr] for example) in a log message?
Steve_McCarthy_
Historic F5 Account
Re: Tcl expression in log message, from the article: "Beginning with releases in 2015, selected LTM Policy actions support Tcl command substitutions and the ability to call standard iRule commands." Look for your expression to work in 12.0.
amolari
Cirrus
Cirrus
very powerful but very poorly documented in the manuals. TCL "Supported since beg of 2015" or some in v11.4. Great, but should be documented
Tosin_Omojola
Altostratus
Altostratus
This is a great eye-opnener for me as I was having trouble setting up some referrer-based redirect using iRules. This led me to the Policy feature and I have just configured it exactly the way I want it to work. How then do I attache it to the VS involved....still looking
Okay. I've seen it.
Steve_McCarthy_
Historic F5 Account
From Virtual Server List screen, click on the name of the specific virtual server you'd like to attach the policy to. Then click on the Resources tab - this brings up the screen where you can select iRules, Load Balancing, and Policies.
lanruibin
I would like to know the difference between http-URI /a and /a/, thank you
Version history
Last update:
‎21-Jan-2015 14:00
Updated by:
Contributors
