iRule: passing client cert to node
In this case, the BIG-IP is terminating SSL connections but the backend web server needs the information from the certificate but doesn't want the BIG-IP to re-encrypt the traffic to the node.
We have successfully configured the BIGIP device to require client certificates - it accepts the certs and passes the traffic through. Now, we need to be able to read and manipulate the client cert at the backend IIS web server via ASP/ASP.NET code.
No problem. With iRules you have full access to the client certificate and it's fairly simple to base64 encode the entire client certificate in a HTTP header and pass it to the backend webserver. Here's what wthem finally came up with with some guidance from the DevCentral team.
when CLIENTSSL_HANDSHAKE { set cur [SSL::sessionid] set ask [session lookup ssl $cur] if { $ask eq "" } { session add ssl [SSL::sessionid] [SSL::cert 0] } } when HTTP_REQUEST { set id [SSL::sessionid] set the_cert [session lookup ssl $id] if { $the_cert != ""} { HTTP::header replace SSLClientCert [b64encode $the_cert] } }
Search Google for Base64 and VB and you should find a implementation of the decoding method (or check the forum thread below...
Click here for the original thread.
-Joe
[Listening to: Ants Marching - Dave Matthews Band - Central Park Concert (2 of 3) (05:51)]
Published Jul 27, 2005
