on 21-Jan-2020 12:43
The insertion of inline security and application delivery devices into an existing network infrastructure can require significant network re-design and architecture changes. Deploying tools that operate transparently at Layer 2 of the OSI model (L2) can greatly reduce the complexity and disruption associated with these implementations.
F5’s BIG-IP hardware appliances can be inserted as L2 devices in existing networks. This can be achieved using either virtual Wire (vWire) or by bridging 2 Virtual LANs using a VLAN Groups.
This article focusses on the configuration of vWire on a standalone BIG-IP with 2 physical interface. The 2 physical interfaces are bridged together and allow traffic through the BIG-IP behaving like a wire.
Note: Virtual Wire is available on BIG-IP hardware.
For more information on F5 security and other modules and their configuration please refer to www.f5.com to access user guides, recommended practices and other deployment documentation. The configuration of BIG-IP modules, such as those providing DDoS protection/mitigation or SSL visibility, is beyond the scope of this article and is the subject of other user guides.
Building virtual wires leverages the underlying configuration of two separate VLAN objects that are bridged using a VLAN group. For convenience, going forward, one will be called the “ingress VLAN object” and the other one the “egress VLAN object”. This is significant because, you will be able to use these objects in your configuration to setup listeners and associate them to either VLAN object.
Overview:
Sample Configuration:
The sample below creates a virtual wire that will work with 802.1Q VLAN id. 512.
Configure interfaces to support virtual wire:
root@(localhost)(cfg-sync Standalone)(Active)(/Common)(tmos)# modify net interface 1.1 port-fwd-mode virtual-wire root@(localhost)(cfg-sync Standalone)(Active)(/Common)(tmos)# modify net interface 1.2 port-fwd-mode virtual-wire
Create all VLAN tag VLAN objects:
root@(localhost)(cfg-sync Standalone)(Active)(/Common)(tmos)# create net vlan Direct_all_vlan_4096_1 tag 4096 interfaces add { 1.1 { tagged } } root@(localhost)(cfg-sync Standalone)(Active)(/Common)(tmos)# create net vlan Direct_all_vlan_4096_2 tag 4096 interfaces add { 1.2 { tagged } }
Create specific (802.1Q tag 512) VLAN objects:
root@(localhost)(cfg-sync Standalone)(Active)(/Common)(tmos)# create net vlan Direct_vlan_512_1 tag 512 interfaces add { 1.1 { tagged } } root@(localhost)(cfg-sync Standalone)(Active)(/Common)(tmos)# create net vlan Direct_vlan_512_2 tag 512 interfaces add { 1.2 { tagged } }
Create VLAN Groups:
root@(localhost)(cfg-sync Standalone)(Active)(/Common)(tmos)# create net vlan-group Direct_all_vlan members add { Direct_all_vlan_4096_1 Direct_all_vlan_4096_2 } mode virtual-wire root@(localhost)(cfg-sync Standalone)(Active)(/Common)(tmos)# create net vlan-group Direct_vlan_512 members add { Direct_vlan_512_1 Direct_vlan_512_2 } mode virtual-wire
Don't forget to save:
root@(localhost)(cfg-sync Standalone)(Active)(/Common)(tmos)# save sys config partitions all
Overview:
There is a single interface to create and configure the necessary configuration objects.
From the BIG-IP WebUI (Network>>Virtual Wire):
Once the all the selections are made and you are ready to implement, click on "Commig Changes to System":
The resulting screen will look like the following:
The resulting VLAN configuration will look as follows:
After creating virtual wire objects, VLANs are available for you to configure the desired services. This includes BIG-IP LTM or SSL Orchestrator objects allowing you to take different actions when traffic comes in one or the other "side" of the virtual wire. For example, you might want connections initiated from the LAN (in the picture above) to be decrypted for security inspection purposes, while having traffic coming in from the firewall passed through transparently.
Deploying the BIG-IP in virtual wire mode provides a great way to insert services into your network without affecting the rest of the network configuration, routing and forwarding. The flexibility of the BIG-IP allows you to control the traffic traversing the BIG-IP on what ever VLAN (tagged or not). I hope this has been useful.
Thanks for the article. What is the purpose of creating 4096 vlan (in addition to the one we want which is 511)?
VLAN 4096 is a reserved VLAN number that represents a wildcard. Basically the 4096 VLAN allows all tagged traffic to traverse the BIG-IP.
Adding a specific VLAN number (VLAN 501 in this case) allows the administrator to associate a listener to that specific VLAN. For example if this is deployed with F5's SSL inspection product, you can associate a service chain/topology to that specific VLAN and associate another service-chain/topology to another VLAN (602?).
I hope this answers your question.
