SIP topology hiding and forward proxy
Problem this snippet solves:
SIP calls from inside to outside are forward with topology hiding.
Code :
rule sip_topo_hide_fwd_proxy { # This I-rule allows SIP calls from inside a network to a server outside. It acts as a forward proxy # and hides the internal IP topology by mapping the via and the from headers. This version does not take # any action in regards to the SDP session or the media connection. That connection will be handled # separately. Future version of this i-rule will hopefully take care of the media connection. # This I-rule was developed in conjunction with the customer who tested it and liked it. when SIP_REQUEST { # Log various SIP headers for those who must see to believe. #log -noname local0. "Incoming From: [SIP::header From] To: [SIP::header To]" #log -noname local0. "Incoming URI: [SIP::uri] - call-id: [SIP::call_id] - Via: [SIP::header Via]" # Save the caller IP for use in later mapping. set originator_ip [IP::remote_addr] # This I-rule works as a forward proxy. It is applied to a virtual server with a "Network" range # destination address as opposed to a specific host address. This means we do not have a specific # node to forward the connection to. The specific node IP and Port are captured from the datastream # and assigned below. # If you are using UDP instead of TCP, be sure to uncomment the UDP version and comment the TCP. node [IP::local_addr]:[TCP::local_port] # UDP version #node [IP::local_addr]:[UDP::local_port] } when SIP_REQUEST_SEND { # Set SNAT IP so that we can use it later for mapping. set snat_ip [serverside {IP::local_addr}] # The following hides the FROM HEADER IP addressing. The caller IP is replaced with the Outside snat IP. # Example of a SIP From header format to use as reference. #\"4136\" <4136>;tag=3459266474-613858 # The following extracts the IP address out of the SIP from header. # Sometimes this is the same as the clientside remote IP but by getting it # out of the From header it makes it work in all cases. set from_ip [findstr [SIP::header From] "@" 1 ">"] # Prepare a list for the string map containing the IP in the From/Via header and the load ballencer/self IP. set ip_map [list $from_ip $snat_ip] # Map SNAT IP to original IP found in the From header. set new_from_header [string map $ip_map [SIP::header "From"]] # Remove old From header, and insert the modified one. SIP::header remove from SIP::header insert from "$new_from_header" # VIA Header is transformed similarly to FROM header. # Reference for the SIP Via header format. # SIP/2.0/UDP 172.16.5.28:5060;branch=z9hG4bK46efb99bd134c21a63f7a943dcb05fb7 #4136> : ; ; ; # Map SNAT IP to orignial IP in the Via Header. set new_via_header [string map $ip_map [SIP::header "Via"]] # Remove old Via header, and insert the modified one. SIP::header remove via SIP::header insert via $new_via_header } when SIP_RESPONSE { # Prepare a list for the string map containing the IP in the From/Via header and the load ballencer/self IP. # Please note that this list is the reverse of the one in the SIP_REQUEST event. set ip_map [list $snat_ip $originator_ip] # FROM header re-mapping # Replace SNAT IP with the SBC Node IP. set new_from_header [string map $ip_map [SIP::header "From"]] # Remove old From header, and insert the modified one. SIP::header remove from SIP::header insert from "$new_from_header" # VIA header re-mapping. #log -noname local0. "Replacing IP: [lindex $ip_map 0] with IP: [lindex $ip_map 1] in Via header." # Replace SNAT IP with the SBC Node IP. set new_via_header [string map $ip_map [SIP::header "Via"]] # Remove old Via header, and insert the modified one. SIP::header remove via SIP::header insert via $new_via_header } }
Published Mar 18, 2015
