Michael_Koyfma1
Altocumulus
Altocumulus
Problem this snippet solves:
f5.saas_idp.v.1.0.1rc1
The official release candidate iApp template has been posted to downloads.f5.com in the RELEASE_CANDIDATE directory of the iApp package. This release has the following changes:
  • Added support for BIG-IP v12.1
  • Modified the 'SP Initiated?' field in the iApp to 'IdP Initiated?' and the values to 'No, SP only' and 'Yes, IdP and SP' to make this section more clear.
f5.saas_idp.v.1.0.0rc1
This release candidate version of the iApp template, released on 4/20/16, provides improved functionality and additional options. The deployment guide has also been substantially updated.
f5.saas_idp.v.0.9.0
This iApp allows you to configure F5 BIG-IP Access Policy Manager(APM) as SAML Identity Provider(IdP) to 11 commonly used SaaS applications:
Office 365
Salesforce.com
Workday
Amazon Web Services(limited support)
Concur
Service-Now
Jive
Wombat
Zendesk
WebEx
Google Apps
How to use this snippet:
For information on how to download, install, and use the iApp (and various other prerequisites), see the deployment guide for this configuration: http://f5.com/pdf/deployment-guides/saml-idp-saas-dg.pdf
Code :
https://downloads.f5.com/esd/product.jsp?sw=BIG-IP&pro=iApp_Templates
Comments
raZorTT
Hello,
First off thanks for developing this iApp!
I'm trying to configure the BigIP as an IdP for a custom service provider.
I tried following the guide and before deploying the iApp I have created a Local IdP Service and an SP connector with details from the service provider.
When I try to deploy the iApp, I selected the local IdP service as the application and the SP connector as the SP. In this case what should I be putting in "What EntityID do you want to use for your SaaS applications?"
Should I put the same EntityID as I created in the Local IdP Service? Or something different? I have tried both and I get the following error when I try to deploy the iApp
01070712:3: Values (/Common/i_saml_idp_SAMLF5_saml_sso) specified for SAML Resource (/Common/i_saml_idp_SAMLF5_saml_resource_sso): foreign key index (saml_sso_config_FK) do not point at an item that exists in the database.
Any help appreciated.
Cheers,
Simon
GahanP_31299
Hi There
having the exact same issue as Simon
have checked the config dozens of times and cannot work out where this error comes from ? :-S
any info appreciated thnx -gahanp
=== BIG-IP APM version 13.1.0.3 build 005 ===
Version history
Last update:
‎01-Nov-2015 20:43
Updated by:
Contributors
