Retry_HTTP_post_request,_including_payload,_to_a_secondary_pool_if_primary_pool_fails
Problem this snippet solves:
So this is just a clean up of Terje Gravvold's iRules found in http://devcentral.f5.com/Forums/tabid/1082223/asg/50/showtab/groupforums/afv/topic/aff/5/aft/59759/Default.aspx
We tried to implement it, and found some bug fixes and minor improvements along the way. Enjoy
Code :
when CLIENT_ACCEPTED {
  # Set initial retry count to zero
  set retries 0
  # Set debug level for iRule
  set debug 6
  # Set HTTP status code to look for
  set status_code 5
  # Log client info about connecting client
  if { $debug > 0 } { log local0.alert "From [IP::remote_addr]:[TCP::remote_port] To: [IP::local_addr]:[TCP::local_port]" }
  # On first try, set request variables and capture request payload (XML post data)
  if { $retries == 0 } {
    # Set request, HTTP post header.
    set request [HTTP::request]
    # Set payload content legth to capture.
    if {[HTTP::header exists "Content-Length"] && [HTTP::header "Content-Length"] <= 4000000}{
      set content_length [HTTP::header "Content-Length"]
    else {
      set content_length 4000000
    # Capture HTTP payload from request, HTTP::collect triggers event HTTP_REQUEST_DATA
    if { [info exists content_length] && $content_length > 0} {
      HTTP::collect $content_length
    # Set default pool to send first request to.
    pool pool_tst_wps-celle-1
    # Log request
    if { $debug > 5 } { log local0.alert "Request: $request" }
when HTTP_REQUEST_DATA {
  # Set payload, depends on HTTP::collect done in HTTP_REQUEST event.
  set payload [HTTP::payload]
  # Append HTTP payload to HTTP request header to form a complete HTTP post request (request + payload)
  append request [HTTP::payload [HTTP::payload length]]
  # Log payload
  if { $debug > 5 } { log local0.alert "Payload: $payload" }
when LB_SELECTED {
    # Log LB pool/server selection
    if { $debug > 0 } { log local0.alert "Server Selected $retries: [LB::server pool] [LB::server addr]:[LB::server port]" }
  else {
    # Reselect LB pool if retries > 0
    LB::reselect pool pool_tst_wps-celle-2
    set retries 0
when HTTP_RESPONSE {
  if { [HTTP::status] starts_with 50 } {
     # Retry if HTTP 50x response and retry count equals zero.
        # Increment retries by 1
        incr retries
        # Retry HTTP request/payload to another another server. This command triggers LB_SELECTED event.
        HTTP::retry "$request"
        if { $debug > 0 } { log local0.alert "Process NOT found in pool [LB::server pool], detaching pool member [LB::server addr]:[LB::server port]" }
        if { $debug > 5 } { log local0.alert "Request retry: $request" }
     else {
        if { $debug > 0 } { log local0.alert "Process NOT found in any pool, [HTTP::status] sent to client." }
  else {
     # Non HTTP 50x response.
     if { $debug > 0 } { log local0.alert "Process found in pool [LB::server pool], request served by pool member [LB::server addr]:[LB::server port]" }
when LB_FAILED {
     incr retries
  else {
Published Mar 18, 2015
Was this article helpful?
