Michael_Everet1
Historic F5 Account
Problem this snippet solves:
Python script which pulls O365 URL's/IP's from microsoft published XML formatted list, parses into python dictionaries formatted for F5 data group, and uses F5 Python SDK to create or update data groups on BIG-IP for each MS product. The script will check if the data group already exists, and if so update based on changes. Once the data groups are installed they can used/referenced by any F5 feature/configuration that can reference a data group.
How to use this snippet:
Python version: 3.6
Python Modules Required: * f5-sdk * requests * f5-icontrol-rest * xmltodict
Update script variables for your environment: BIGIP_ADDRESS = ' ' BIGIP_USER = ' ' BIGIP_PASS = ' '
to execute: python3 o365_dg_builder.py
Code :
import requests
import xmltodict
from collections import OrderedDict
from f5.bigip import ManagementRoot
from icontrol.exceptions import iControlUnexpectedHTTPError
import argparse
MS_URL = 'https://support.content.office.net/en-us/static/O365IPAddresses.xml'
BIGIP_ADDRESS = '192.168.15.165'
BIGIP_USER = 'admin'
BIGIP_PASS = 'admin'
def load_bigip(f5_host, f5_user, f5_pass):
    bigip = ManagementRoot(f5_host, f5_user, f5_pass)
    return bigip
def get_o365_data():
    o365data = requests.get(MS_URL)
    records = []
    pdata = xmltodict.parse(o365data.content)
    for product in pdata['products']['product']:
        prod_name = product['@name']
        if isinstance(product['addresslist'],list):
            for addrlist in product['addresslist']:
                record = {}
                if 'address' in addrlist.keys():
                    record['name'] = "{}_{}_{}".format('MS',prod_name, addrlist['@type'])
                    if '@type' in addrlist.keys():
                        if addrlist['@type'] == 'URL':
                            record['type'] = 'string'
                        elif (addrlist['@type'] == 'IPv4' or addrlist['@type'] == 'IPv6'):
                            record['type'] = 'ip'
                    # MS XML has duplicate entries, unify the list before adding to record
                    new_addr_l = list(set(addrlist['address']))
                    record['records'] = new_addr_l
                    records.append(record)
        if isinstance(product['addresslist'],OrderedDict):
            if len(product['addresslist']['address']) > 0:
                record = {}
                record['name'] = "{}_{}_{}".format('MS', prod_name, product['addresslist']['@type'])
                if product['addresslist']['@type'] == 'URL':
                elif product['addresslist']['@type'] == 'IPv4' or product['addresslist']['@type'] == 'IPv6':
                record['records'] = list(set(product['addresslist']['address']))
    return records
def compare_dg_entries(record, old_dg_l):
    # let's get the values to compare, and see what updates we need to make
    #compare lists
    addrs_to_rem = [x for x in old_dg_l if x not in record]
    addrs_to_add = [x for x in record if x not in old_dg_l]
    return addrs_to_rem, addrs_to_add
def create_dg(bigip, record):
    if not bigip.tm.ltm.data_group.internals.internal.exists(name=record['name']):
        bigip.tm.ltm.data_group.internals.internal.create(**record)
        create_status = 'SUCCESS'
    else:
        old_dg_entries = bigip.tm.ltm.data_group.internals.internal.load(name=record['name'])
        # pull into a list
        old_dg_l = []
        for entry in old_dg_entries.records:
            old_dg_l.append(entry['name'])
        addrs_to_rem, addrs_to_add = compare_dg_entries(record['records'], old_dg_l)
        if len(addrs_to_add)==0 and len(addrs_to_rem)==0:
            create_status = 'SKIPPED'
        else:
            if len(addrs_to_rem) > 0:
                for addr in addrs_to_rem:
                    old_dg_entries.records.remove(next(x for x in old_dg_entries.records if x['name'] == addr))
            if len(addrs_to_add) > 0:
                for addr in addrs_to_add:
                    old_dg_entries.records.append({'name':addr})
            old_dg_entries.update()
            # if you get time create log of updated entries
            create_status = 'UPDATED'
    return create_status
try:
    bigip = load_bigip(BIGIP_ADDRESS, BIGIP_USER, BIGIP_PASS)
except iControlUnexpectedHTTPError as e:
    print(e)
    exit(1)
if bigip:
    records = get_o365_data()
    for record in records:
        try:
            status = create_dg(bigip, record)
            print("BIGIP: {}, Data Group: {}, Create Status {}".format(BIGIP_ADDRESS, record['name'], status))
            status = 'FAILED'
            print("BIGIP: {}, Data Group: {}, Create Status {}, Error {}".format(BIGIP_ADDRESS, record['name'], status, e))
Tested this on version:
13.0
Comments
NUT2889
Right now Microsoft change to use JSON format instead via https://endpoints.office.com/endpoints/worldwide?clientrequestid=b10c5ed1-bad1-445f-b386-b919946339a...
The parser in python script might not working with JSON format right?
Version history
Last update:
‎14-Mar-2018 07:38
Updated by:
Contributors
