Andy_McGrath
Cumulonimbus
Cumulonimbus
Problem this snippet solves:
The SSL port is assigned in the following line:
lreplace $loc_list 2 2 [lindex [split [lindex $loc_list 2] ":"] 0]:80
change the ':80' to any required port to remove to remove any port assigned within the Location Header.
How to use this snippet:
Code :
# Rewrites the HTTP Location header in a HTTP Reponse from HTTP to HTTPS and a none standard port to the end of the hostname
# e.g. Location Header 'http://www.test.com/path1/path2/index.html' will be changed to 'https://www.test.com:80/path1/path2/index.html'
when HTTP_RESPONSE {
    if {[string tolower [HTTP::header Location]] starts_with "http://" }{
        #Splits the Location Header string into a list
        # e.g. http://www.test.com/path1/path2/index.html = 'http:', '', 'www.test.com', 'path1', 'path2', 'index.html'
        set loc_list [split [HTTP::header Location] "/"]
        # Replaces list location 0 (first item) with 'https:'
        # e.g. list item 0 = 'http:' and is replaced with 'https:'
        lreplace $loc_list 0 0 "https:"
        # Appended the port number to list location 2 (the FQDN), if a port is already defined this will replaced
        # e.g. list item 2 = 'www.test.com:897' is replaced with 'www.test.com:80'
        # e.g. list item 2 = 'www2.test.com' is replaced with 'www2.test.com:80'
        # List items are joined back together with '/' inserted and set at the new HTTP Location Header
        # e.g. list = 'https:', '', 'www.test.com:80', 'path1', 'path2', 'index.html' becomes 'https://www.test.com:80/path1/path2/index.html'
        HTTP::header replace Location [join $loc_list "/"]
Tested this on version:
11.5
Comments
Pavel_Stoyanov_
Getting the following error on BIG-IP v11.6.0.8.0.482:
01070151:3: Rule [/Common/HTTP_to_HTTPS_Location_rewrite_with_custom_port] error: /Common/HTTP_to_HTTPS_Location_rewrite_with_custom_port:14: error: [wrong args][lreplace [$loc_list 0 0 "https:"]] /Common/HTTP_to_HTTPS_Location_rewrite_with_custom_port:19: error: [wrong args][lreplace [$loc_list 2 2 [lindex [split [lindex $loc_list 2] ":"] 0]:80]]
7Samurai
Same comment as above. What gives? Does anyone read these comments? This irule, as written, generates the errors Pavel Stoyanov pasted above. How do we fix this?
Stanislas_Piro2
Cumulonimbus
Cumulonimbus
lreplace command doesn't replace any value in list but returns a new list with replaced value.
you can use this command :
set loc_list [lreplace $loc_list 0 2 https {} [lindex [split [lindex $loc_list 2] ":"] 0]:80]
or
set loc_list [lreplace $loc_list 0 2 https {} [getfield [lindex $loc_list 2] ":" 0]:80]
Version history
Last update:
‎26-Oct-2015 10:54
Updated by:
Contributors
