Artiom_Lichtens
Historic F5 Account
Problem this snippet solves:
Usage:
**http**://VS_IP/**geo?**{IPv4_TO_TEST | IPv6_TO_TEST}
Examples:
http://10.100.89.100/geo?8.8.8.8
http://10.100.89.100/geo?199.19.105.220
http://10.100.89.100/geo?2a02:DB8::45
How to use this snippet:
iRule Source
https://github.com/ArtiomL/f5networks/tree/master/irules/geo-query
Sample Output
IP: 199.19.105.220
GeoLocation Data
Continent: NA
Country: US
State: Texas
ISP: Network operations center inc.
Org: Volumedrive
IP Reputation: Scanners Proxy
Code :
#!iRule
# F5 Networks - iRule: GeoLocation and IP Reputation Query
# https://github.com/ArtiomL/f5networks
# Artiom Lichtenstein
# v1.7, 21/07/2016
# Usage:
# http://VS_IP/geo?{IPv4_TO_TEST | IPv6_TO_TEST}
# Examples:
# http://10.100.89.100/geo?8.8.8.8
# http://10.100.89.100/geo?199.19.105.220
# http://10.100.89.100/geo?2a02:DB8::45
if { [HTTP::uri] starts_with "/geo" } {
set str_GEO_RESPONSE "Please Enter IPv4 / IPv6 Address:"
set str_IP_ADDR [substr [HTTP::uri] 5]
if { ![catch {IP::addr $str_IP_ADDR mask 255.255.255.255}] } {
 log local0.info "IP: $str_IP_ADDR"
set str_GEO_RESPONSE "IP: $str_IP_ADDR
GeoLocation Data
" array set arr_GEO_DATA { aContinent 0 bCountry 0 cState 0 dCity 0 eZIP 0 fArea_Code 0 gLatitude 0 hLongitude 0 iISP 0 jOrg 0 } set lst_SORTED_ARR [lsort [array names arr_GEO_DATA]] foreach i $lst_SORTED_ARR { set str_GEO_FIELD [substr $i 1] set arr_GEO_DATA($i) [whereis $str_IP_ADDR [string tolower $str_GEO_FIELD]] if { ([string length $arr_GEO_DATA($i)]) && ($arr_GEO_DATA($i) ne "0") } { set str_GEO_RESPONSE [concat $str_GEO_RESPONSE "
$str_GEO_FIELD:" [string toupper $arr_GEO_DATA($i) 0 0]] log local0.info "$str_GEO_FIELD: $arr_GEO_DATA($i)" } } set lst_IP_REP [IP::reputation $str_IP_ADDR] if { [llength $lst_IP_REP] == 0 } { set lst_IP_REP "Good" } else { log local0.info "IP Reputation: $lst_IP_REP" set lst_IP_REP [concat "" $lst_IP_REP ""] } set str_GEO_RESPONSE [concat $str_GEO_RESPONSE "
IP Reputation:" $lst_IP_REP] } HTTP::respond 200 content [subst { F5 GeoLocation
$str_GEO_RESPONSE
Tested this on version:
12.0
Version history
Last update:
‎17-Mar-2015 14:15
Updated by:
Contributors
