Michael_Jenkins
Problem this snippet solves:
This snippet shows how to get the actual number of CCUs used at the current time for APM.
How to use this snippet:
Execute this command from the CLI. The second line will show the current number of CCUs used.
Code :
echo -e 'get tmm.license.global_connectivity#\r' | nc 127.1.1.2 11211
Tested this on version:
11.5
Comments
JG
Cumulonimbus
Cumulonimbus
This returns nothing on v11.6.0HF4.
KimiLi_147173
Do not get any output on v11.2.1
F5_Jeff
Cirrus
Cirrus
have you tried this command instead?
tmsh show /sys license detail | grep apm _ access _ sessions
Version history
Last update:
‎29-Jun-2015 11:47
Updated by:
Contributors
