Kevin_Davies_40
Nacreous
Nacreous
Problem this snippet solves:
Store headers for all requests/responses sent through an application and you can view them from the BIGIP.
How to use this snippet:
Connection Monitor
Requires: client ssl profile, http profile, tcp profile.
  • Define the application name. Update "changeme" in CLIENT_ACCEPTED. Must be unique. No spaces.
  • Assign to application virtual server.
Connection Tracker
Requires: http profile, tcp profile
Optional: client ssl profile
  • Create http virtual server on same BIGIP
  • Assign the connection tracker iRule
  • Navigate to default page
  • Select the application name you defined above
Code :
70949
Tested this on version:
11.6
Version history
Last update:
‎28-Sep-2016 04:35
Updated by:
Contributors
