Which interface does f5 updates itlsef as signatre attack updates and hotfixes ?? from mangement or self IPs or floating IP ???
Hi Ahmed,
it will be the management IP or a self IP depending on your routing configuration.
I do not expect the floating self IP to be used. Thanks, Stephan
PS: Personally I prefer to turn off the auto update check feature on all my systems.
